Question about Olevia Televison & Video
Tv will not turn on...it has power as the blue light is lit.
Will not turn on with remote,or manually
Just unplugged the tv and waited a couple of minutes. Then plugged it back in,and it worked!!
Posted on Jun 21, 2009
Lcdx37whd88
Sounds like your power supply capacitors have failed. Google for Z1234TV and see if you can locate a power supply capacitor repair kit for your model.
Mar 31, 2012 | Televison & Video
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Red power indicator is lit, this will turn to a blue light with the Insignia logo lit when it comes on unfortunately it will not turn on either manually or with the remote.
Hi:
Have the power supply checked for puffy capacitors that are swollen on their tops. This is a common problem with LCD televisions. The problem is the five volt standy voltage is to low to turn the set on or operate the Micro. These caps are usually valued at 1500u,voltage rating of 10-16volts. some units use 3300uf rated at 10 volts for theirs capacitors. I suggest you use 2200uf rated at 16 volts.
Apr 20, 2011 | Insignia NS-L22X-10A 22 in. HD-Ready TV
Remote for box 1 is changing channels for remote 2 and remote 2 does not work
lieslmc
Are you getting the same picture on both TVs - TV 1 and TV 2? Depending on the receiver model, you have a mode button either on the front of the receiver or behind a door on the right side of the receiver. You also should have a green (TV 1), amber (mode), and blue (TV 2) lights on the receiver. If TV 2 is one, the blue light should be lit. The amber light should be lit under the dual mode. Press and release the mode button on the receiver to put the receiver in dual mode. The blue light (TV 2) should illuminate now and this will give you independent operation between the two TVs. I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
Vivanco tt 716 remote instructions
I have a manual. What part do you need?
To retune the remote to your TV automatically press Power & Mute keys together. Then press TV key. You should have a blue light & a red light. Now press & hold the Power button until the blue light blinks twice & release. The remote will search for your code. If the TV turns off (sorry forgot to mention TV should be on first) quickly press the TV button again to store the code. Then press the Power button to check if the TV turns on again.
If you need the codes. Let me know
Sep 29, 2009 | Televison & Video
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
Jul 04, 2009 | DISH Network 322 DTV Receiver
Polaroid Flat Panel TV FLM 373B
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
Apr 13, 2008 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
