Question about Jensen's VM9312 Car DVD Player
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
    New Friend:
  • 85 Answers
It connects to the Back-up camera if you have one installed. if not leave it out of the hook up.
Posted on Jun 26, 2009
  • 77 Answers
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Posted on Jun 21, 2009
SOURCE:
How do i hook up a ipod to the stereo?
You will need to use the Media link provided with deck (it should have come in box) If you had purchased the deck form a private seller you can find it on ebay here are the links for the media link and the ipod attachment cable...
Media Link http://cgi.ebay.com/JENSEN-MEDIALINK-4-iPOD-INPUT-VM9512HD-VM9312-VM9312HD-/230561415259?pt=LH_DefaultDomain_0&hash=item35ae88005b#ht_2062wt_905
Ipod Sync cable for Media Link http://cgi.ebay.com/iPOD-iPHONE-CABLE-MSR3007-MSR2007-VM9312-VM9312HD-UV9-/190448728210?pt=Car_Audio_In_Dash_Receivers&hash=item2c57a0f892#ht_2628wt_1139
Jan 08, 2011 | Jensen VM9312HD Car DVD Player
Were can i get my jensen vm9312hd radio fixed and for how much
try going to audiovox.com. audiovox now owns jensen.
Jan 03, 2011 | Car Audio & Video
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
Nov 13, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Jensen's VM9312HD when i put the disc say's bad disc
it might need a lens cleaner disc...this is a common problem of using discs
Aug 10, 2009 | Jensen's VM9312 Car DVD Player
Where does the green/white reverse + wire hook to?
connect to you reverse light circuit dont guess it have an proper installer do it for you
Jul 07, 2009 | Jensen VM9020TS Car DVD Player
Where can I get a replacement owner's instruction?
there is 2 manuals vm9321 and vm9312hd , you choose from this link to the jensen site .
manual vm9312
J5
Jan 16, 2009 | Jensen's VM9312 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
1,524 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
