Question about Brother MFC-5840CN All-In-One InkJet Printer
when is printing the sentences comming on angel not straigt only 1/3 part of the sheet and then the problem fix it.
  • 832 Answers
Did you run a test sheet print? It might be that the nozzles are clogged. Run the ink cleaning cycle.
Dont clean the metal rail with WD40 oil! The printhead (and the rail) has to be lubricated with a special molycote that doesnt attack the plastic.
Posted on Nov 10, 2007
Hi Gera.
The above problem sounds like the rail that the printer unit runs along is clogged up, open up the top cover, spray a little WD40 on to a cloth and wipe the rail. (Do not spray WD40 directly onto the rail that runs through the printer unit), if this does not work you will notice a thin plastic strip running through the print head this may also require cleaning, be very careful with this as you may dislodge it, it will require an engineer to reinstall it.
Posted on Nov 08, 2007
0 characters
3 Points
Printing jobs are coming out blank
Does this happen if you make a copy? Or print any internal form meter count sheet demo page etc.
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
I have Canon ipf 650 , it doesnt show any eror, the problem is it is new plotter, printed very few, and stoped printing only empty sheets were coming out, we changed printhead and again the same, empty...
With this type of plotter there really is very few possibilities. Replace the ink cartridge with a manufacturer original cartridge. If that doesn't work, change your paper. If still no print, send it back to Canon on a warranty replacement.
Aug 22, 2013 | Canon imagePROGRAF iPF650 largeformat ...
Black spots on printed sheets. I think the rollers need cleaning. I have a Ricoh Aficio AP 600
If you are getting black spots on printed sheets,
you should clean the rollers or replace it.............
thank you.........
Jul 23, 2011 | Ricoh Aficio AP600N Laser Printer
Printed out a inkjet magnet sheet now won't anything else! Help!
OK Christina, did the whole magnet page come out without any missing tear outs or pieces? You probably have a stuck piece of sticky paper in your feed or rollers. Look in your manual for clearing paper jams and examine your rollers while your at it from stray pieces of paper.
Jun 27, 2009 | Printers & Copiers
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark X7170 not ejecting printed sheets
Time to get a new printer, because you cannot get the parts.
Mar 01, 2007 | Lexmark X7170 All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
128 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
