Question about Westinghouse WST3501 Microwave Oven
Dead keypad I have the same problem worked fine before I moved now clock and light are okay but keypad dead
    Sergeant:
  • 212 Answers
Need to check keypad ribbon tail or connection. vibration from moving unit could have made it come loose. if connection are good then replace keypad.
Posted on Jun 21, 2009
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
I have a GE Spacemaker JVM1540SN1SS. It stopped working without any warning: no light or clock or anything. Just dead weight. Any ideas?
It indicates the main fuse in the microwave oven has opened, probably one of the main parts have failed, possible causes, magnetron, inverter board, and the keypad control board.
Apr 18, 2012 | GE Spacemaker JVM1740 Microwave Oven
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Control Panel "clock Buttom" dead
Sounds like your keypad has failed, and on some models it's not available separately, so you have to buy the entire control panel assembly.
You have to remove the controller (see the video here) then unplug the keypad strip (see photo below) then move your circuit board to the new control panel assembly (part #
WB07X10798 if that's the right one for your model).
See exploded views
here. You can find this part for $101.91 here (compared to $163.50 from G.E.!).
Jul 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
280 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Devabhakthuni...
Devabhakthuni...
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
