Question about GE 17.1 cu. ft. / 484 liter Upright Freezer FUM17DMRWH
Freezer has lost its suction & no longer freezing!
I hear no motor assy that is bad or any other "noises"...pulled the freezer out & see nothing out of the ordinary underneath where the compressor & motor is. It is no longer freezing & has also lost the suction when the door is shut. I am confused! Does it take some sort of coolant charge? Help! Thanks, Tim
  • Tim Michael Jun 21, 2009
    Thanks for responding. Is this something a common guy like me can do going down to the local FixIt store & buy some freon? Or is it best to have a certified repair guy come out to do this? Thanks!
    Sergeant:
  • 212 Answers
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Posted on Jun 21, 2009
  • kenrick driscoll Jun 21, 2009
    you have to be licensed to buy freon. you need an experiened tech to evacuate system
Freezer does not work , it was shut down for a year , what can i do ?
Can you provide a little more information? Like what happens when you plug it in?? Nothing? Funny noise?? Motor runs but no cooling occurs?
Nov 17, 2014 | Freezers
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Does not get cold
Hello bprice7777 - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
Nov 13, 2012 | Frigidaire 5 cu. ft. / 142 liter Chest...
Is there anyway to test start relay for a freezer
Hello - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 30, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Whirlpool Freezers
Freezer not freezing - can hear a clicking noise coming from areond the th.ermostat / motor area
My freezer has a light that says "high temp" but the freezer isn't freezing my products.....what can I do? It also says that the temp has been 23 degrees or higher for more than 1 hour. I really don't think that the problem is being in hot weather
Apr 22, 2011 | Freezers
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
GE 17.1 cu. ft. / 484 liter Upright Freezer FUM17DMRWH Logo
636 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
