Question about GE GSS20IEP Side by Side Refrigerator
Not cooling properly
My refrigerator is not cooling and the freezer is making see through ice and water is starting to melt in the freezer.
    Sergeant:
  • 212 Answers
You need to have the freon pressure checked. if low the unit will not cool properly. if not cooling at all you need to verify that the compressor is running. if so then you have a sealed system leak. if not then check your ptc and overload on compressor. that is your start device for your compressor. unit could be stuck in defrost but not likely with a ge. usually the hv board would go out. if that is the case then you would have no power to unit
Posted on Jun 21, 2009
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jcb 2059 ges Jen air fridge part not cooling freezer o.k.
If freezer cooling but fridge not cooling,then its a defrost issue.First freezer cools,then cool air from freezer gets to fridge and fridge gets cool.But if freezer defrost cycle not taking place then its faulty defrost assembly parts.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Jenn-Air JCB2059G Bottom Freezer...
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
My Hoover Frost Free A class HTK 95AA has a trickling water noise coming from the back around the cooling pipes when switched on. The compressor gets very hot although the cooling pipes do not, is it
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Sub zero 561, evaporator is icing. 1st tech came in and after checking gas pressure told us that evaporator is leaking. we called in secong tech, he filled up gas and it started cooling fine but couple...
It may be leaking but I think more likely is that you have a problem with the defrost system and it is not defrosting properly... that can give the same symptoms as a low charge or leak condition...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Sub-Zero 561 / F
Our Zanussi fridge is frost free type. Last week, the thick ice on the fresh food section of fridge (upper part) was melted by itself and leak the water everywhere. After we cleaned it out, the fresh...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Zanussi ZEBF250W Bottom Freezer...
My ice maker quit making ice on my amana bottom freezer
Hi, If your ice maker has stopped making ice then you need to check these things.
The lever that controls the ice maker has been pushed up which turns it off. If you have a red lever, pull it down to the wire and if you just have a wire then just pull down the wire to start your ice maker up.
Make sure the freezer temperature is below 10 degrees F If the freezer is too warm ice production will be poor because the ice maker will not cycle properly.
The ice maker fill tube may have ice formed in it, blocking it. Use a hair dryer to melt the ice. Watch out for the plastic parts, so that you do not melt the plastic. Also check the water inlet valve and the shut off valve, to make sure it is not plugged with debris. The openings in those valves are very small.
Check the gears in the ice makers to see if they are broken or stripped. Also look to see if the ice rake is broken. All parts in the ice maker are replaceable individually, If you find broken parts replace them.
Take care
Jul 23, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer is icing up behind back panel, so fridge not cooling
There are two components that are supposed to take care of this problem. One is a heater that defrosts the system (not really frost free) and the other is a timer that turns the heater on and off at predetermined intervals.
If the heater or timer fails, the system will frost up and block the path of cool air not allowing the freezer to cool down.
Jul 20, 2009 | GALAXY Microsystems 63702 Top Freezer...
GE GSS20IEP Side by Side Refrigerator Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
