Question about Sony GV-D1000 Mini DV VCR
Irrational Battery message on Sony GV-D1000
My Sony GV-D1000, which has worked just fine for years, now exhibits this behavior: Whenever I try to rewind more than a few minutes on the tape, it stops, displays the message "For InfoLithium Battery Only" and then shuts itself off. NOTE: I have never used a battery with this deck, I power it only with the supplied power adapter. It is my editing deck.
  • 158 Answers
SOURCE: Tape stuck inside
there is screws on the unit when the unit goes into rewind mode disconnect from mains and unscrew unit first check to see if the screws are scurity type haveng a hex or star shape on them if either then take to video and tv repair shop and explain that you need to remove a tape from unit you may have to pay for a small fee for it to be removed this part is all i can give but if you can remove screws yourself then locate the motor for tape ejet and load and manualy wind till tape is removed good luck
Posted on Aug 13, 2007
SOURCE: DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
Posted on May 13, 2008
  • 36 Answers
SOURCE: Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
Posted on Feb 11, 2009
SOURCE: For Info Lithium Battery only
I was having the same problem with a sony GV-D1000 which I don't even use a battery with. I use an AC adapter. Someone suggested that the contacts might be dirty, so I unplugged the small connector that plugs into the back of the deck and wiped it hard with my t-shirt. It seems to work fine now. SO try cleaning the contacts (wherever your adapter or battery connects with the deck or camera.)
Posted on Jun 21, 2009
  • 221 Answers
SOURCE: sony gv d1000
Sounds like an exit guide mis-alignment or a worn pinch roller.
Posted on Apr 06, 2010
Hi there How can we connect Sony GV-D1000E with MacBook Pro (2010 model) please?
You need a firewire cable.
Most likely a 4 to 6 pin unit unless the Mac has an 800 port, then use a 4 to 9 pin.
Feb 24, 2011 | Sony GV-D1000 Camcorder
Sony gvd 1000 wont work comes up with code c 31.10
The 31 indicates a motor movement problem. The 10 indicates which one. I don't have the manual handy so I can't look up the specific motor movement that is wrong. These units are tricky to work on and are not DIY repair machines. Please seek an authorized service centor for this repair.
Dan
Jan 18, 2011 | Sony GV-D1000 Mini DV VCR
I would like to buy a repair manual for the sony repair manual mini DV-1000 recorder player
Required service manual can be downloaded from HERE for small fee.
Hope this info helps you.
Thanks.
Jan 03, 2011 | Sony GV-D1000 Mini DV VCR
My sony GV-D1000 will is not being recognized by my apple computer, this happened out of no where..Please please help
try reebooting your computer and plugging it back in or leave youre computer off for the night and try again in the morning
Feb 12, 2010 | Computers & Internet
Sony gv d1000
Jan 15, 2010 | Sony GV-D1000 Mini DV VCR
Feb 11, 2009 | Sony GV-D1000 Mini DV VCR
Aug 11, 2008 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 unable to be recognized.
launch video editing software...it should be able to see your deck. none of my three macs "recognize" the deck, but finalcut pro sees and can control the deck once it is connected and turned on
Nov 29, 2007 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 Mini DV VCR Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
