Question about Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v
Problems wiring Flotec sprinkler pump
The pump is wired for 220. Does it matter which wire is on which terminal. The terminals are labeled L1 and L2.
I've seen in other posts that it should be Black to L1 and Red to L2. The problem I am having is neither wire is black or red, they are both blue.
No matter which way I wire the pump it does not turn on. The old pump motor ran and now I'm very confused.
  • 999 Answers
L1- L2 doesn't care if blk or red. Make sure there is 220vac (240vac) on the supply wires. If there is there is something amiss with the pump. Eric
Posted on Jun 21, 2009
Does the Red wire connect to the L1 or L2 Screw
when hooking up a pump on 220v, there are two hot wires. it doesnt matter which hot wire goes where. both L1 and L2 are power terminals
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Does it matter wrong connection (switching cables) on a single phase electric mottor
Most larger 120 V motors have the option to be wired for 240 V, and as a result need half the current - which translates to lower installtion costs do to a wire size the can be reduced.
These motors have simple terminals like L1, L2 and two or more similar to 1, 2, 3, 4 or A, B, etc. that can be connected that permits selecting rotation direction, speed(s) and voltages.
Nearly all these motors will require that L1 and L2 terminals be connected to the power, whether it is a hot and neutral for a 120 v supply, or hot and hot as would be the case for a 240 v supply. It would then require the correct connection / jumper connection of the other terminals to tell the motor which voltage is being supplied. An incorrect combination here could be disastrous. Either way, L1 & L2 is power in. Consult the label on the motor to correct wiring - and if by chance one of the L1 or L2 terminals is specified for neutral, it should be connected that way.
I hope this helps & good luck!
Apr 26, 2012 | Smith 2hp Pool Pump Motor A O Electric...
Need to know which is pos and neg. L1 or l2?
Pos and negative are DC voltage terms. And that pump is a 220 VAC pump. L1 and L2 are the two HOT terminals - so you will have 110 VAC on one leg and 110 VAC on the other leg and it doesn't really matter which HOT you put on which leg.
Jun 07, 2011 | Waterway Executive 56 Spa Pump 2hp 2" 2spd...
How to install a power cord to a Hayward 1hp Power Flo Matrix pump.
One line lead wire to the L1 terminal, the other line lead wire to the L2 terminal and the green ground wire to the green grounded screw above the motor terminal board. It does not matter which wire, white or black, is on which terminal, L1 or L2, so long as one wire is on each terminal.
John
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Re-installing Flotec 5172 after overhaul. Cannot remember whether white wire goes on top terminal or bottom (near the 115/230 switch)
If you are running the pump on 230v it will not matter which terminal you use...if you are on 110v then you need to hook it to the one marked "L2"
heatman101
May 13, 2011 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I bought a red lion sprinkler pump with an A O Smith 1.5HP electric motor on it. A O Smith model # CET50ABH, serial # 27308J2. I knew I would have to wire it (115/230v capable) and I want to go the 115v...
Your black and white wires go on L1 and L2. It will not matter which wire goes on with line terminal as long as you just put one cord wire on L1 and one on L2. Be sure you properly switch the motor to run on 115V since it will facotry prepped for 230.<br /> <br /> John
Aug 18, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
If you are replacing a 2 hp pump with a Hayward 2 hp super pump on a 220 line is L1 white and L2 black
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Jun 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wiring new motor
The L1 and L2 are the load terminals. Connect the black wires to the L1 and L2 and the green one to the green colored screw.
May 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Flotec 1 - 1/2 Sprinkler Pump Composite Quick Priming High - Capacity 115/230v Logo
655 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
