Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT finished the cycle and is locked with no power. We checked the circuit breaker and plug. Even when it has locked in the past, it had power to it, and we could open it. We have a repair man coming in three days. But, I don't like having wet clothes in there that long. Any suggestions would be greatly appreciated.
  • 530 Answers
Take the kick panel off and reach up the right side of where the door latch there is a hook to pull. pull it down and it will unlock your door. dont pull too hard though you don't want to break it. let me know how it goes
Posted on Jun 21, 2009
2 Suggested Answers
  • 662 Answers
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a duet HT and the control is locked. how do i unlock thanks
Mine is doing this all the time, I finally got tired of pulling the washer out to unplug it so I plugged the washer into an extension cord that's easily accessable, so unplug it for at least 30 mins before you plug it back in reset to drain and spin cycle for 12 mins and your load should finish ok. These washer and dryers are beginning to be a pain in my....neck.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset a whirlpool duet washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet sport washer often finishes it's cycle with the symbol Sd or 5d, I'm not sure which one. Any idea what that means?
Slow drain. Check your drain hose for kinks and make sure it's not partially plugged. If it is going into a pipe make sure it isn't pushed too far into it.
Sep 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
