"Replacing old irrigation timer with new orbit 20 sta irrigation timer. Three power wires green white and black coming to old timer. New timer has three power connections/posts labeled: "L" & "N" & "E". What does L,N,E mean and which power wires go to which new post? appreciate any help.
  • 15,935 Answers
L = Line Power - black
N= Neutral - white
E = Earth - Green
Thanks for using FixYa!!
Posted on Jun 21, 2009
Orbit timer 57899 no AC
Transformer is probably burned out. If it is a indoor timer buy a new 24V transformer. If it is a outdoor timer buy a new one.
Apr 28, 2013 | Orbit 9 Station Super Dial Irrigation...
Replace et724-A with new digital timer 15313
You are install GE 15313 timer
Open following link to identify timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
15313 timer does not require Neutral wire.
The timer you are replacing has neutral wire (White wire)
So replace timer wires 1:1 except do not connect timer to white neutrals.
Keep in mind the 15313 is for incandescent lights only and is not for CFL or LED lights.
If you want timer for CFL, then install one of the other timers shown on page.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 29, 2012 | Intermatic Inc. EJ500C Digital Wall Switch...
I am replacing an old SS5 timer with this new one (ST01C) to control two sconces in my dining room. My question relates to the wiring. My old timer has three leads. The new one has four. In the switch...
Open following link to see clear drawing and instructions for wiring ST01C timer.
Page also has EZ programming steps:
http://waterheatertimer.org/ST01C-program.html#ST01C
Red wire is capped.
Blue wire goes to Load (wire to sconces)
Black wire connects to Line wire (wire from breaker)
Green wire goes to ground.
If you are uncertain about Load and Line wires, just connect them either way, turn power ON, push on-off button, it lights don't come on, then reverse wires.
I have tested this timer, and information here is correct.
Don't forget to install CR2 battery, otherwise display will not show.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Intermatic Inc. ST01C Digital In-Wall...
GE Timer #15086 has red, white, green, black wires. Wall has white, black & black wires and switch sits between 3 other light switches. (I am replacing the current timer which only has 3 wires and...
GE 15086 programmable timer replaces single-pole switch only.
Single pole means 1 device turns Load on-off.
3-way is where 2 devices turn Load on-off, for example 2 switches located in hallway.
Your existing timer has white, black and blue wires.
Your new timer has white, black, red and green wires.
Green wire connects to bare ground wire in every occasion with every wiring device.
Electricians don't guess, they test the other wires.
Remove old timer.
Separate wires for testing.
Turn on power.
Tape ordinary tester leads to wood sticks to keep hands away from power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. The Hot wire will connect to timer black wire.
Now test Hot wire to each other wire (except bare ground)
Tester will light up on Neutral wire. Neutral wire connects to timer white wire.
The remaining wire connects to timer red wire.
After connecting timer, push manual override button to check that Load turns on-off.
Manual override on 15086 is the door that covers buttons > use door as push button to check Load.
Next, program the timer.
Programming is straightforward and similar to other timers.
If you have a problem, add a comment.
You can also take advantage of Fixya phone support. Expert will walk you through the steps for a price.
Dec 22, 2010 | Hardware & Accessories
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
I am replacing my old Lutron timer with a new GE 15070. The old one has a black and white wire. The GE has a black, white and red. Black to black and white to white, leaving the red unattached does...
You old timer was a simple one-pole switch. It could connect the black and white (that's ON) or not connect them (thats' OFF) The new timer is a two-pole switch. It is like two switches (A and B) that act opposite each other. In one position A is ON and B is OFF. In the other position B is ON and A is OFF. On your old timer the two wires were interchangeable. But on the new timer you have to know which wire is which. Since you only need one pole of the new switch there are only three combinations to try, and you have already tried one of them. All that matters is which wire on the switch you ignore. Try ignoring a different wire. That will either work or it will operate backwards (being ON when it should be OFF and vice-versa). If that happens, then the third time will be the charm. Good luck, Al K
Dec 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
