Anbna, there is no reset button for your discontinued model. However, you can try resetting it by doing the following:
Turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit in and turn the unit ON.
Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. And the unit will turn ON when you press the ON/OFF Switch.
It's also a good idea to check the outlet it's plugged into. It very well could be an issue with the outlet (no power) or the circuit breaker for that outlet has tripped.
If you continue to have a problem getting it started, contact LG Customer Support 1-800-243-0000.
I hope this helped you to further troubleshoot and solve the problem.
if you carefully examin the compressor/motor, there should be a small red or orange button on the side of it. Or it may be inside the the terminal box.TURN OFF POWER BEFORE YOU START!!!
press the button in firmly and you shoul feel or hear a click.
That is the motor protection 'overload".
once pressed. close it all up and turn on power.
Look inside where the bucket goes in at the top right hand side is the bucket switch. Hold it in and start the unit. If it runs the arm on the switch must be bent SLIGHTLY until it makes contact with the button and the lite goes out with the bucket in.
make sure the float in the bucket isn't binding on something. The float actually activates a button that you can see when you remove the bucket. pull the bucket out and see if the unit cuts off. Maybe the button is stuck.
Problem is that you bought a dehumidifier made by the Korean/Chinese manufacturer LG. Search the web and you will find that you are just one of many whose dehumidifier worked the first year but now draws no water out of the air even though it makes all the right fan and compressor noises. Most common problem is that all the Freon refrigerant escaped, apparently because the copper tubing cracked and leaked. Penguins beware, there goes the Ozone Hole! It cost me $14 and an afternoon of investigation and testing of my LG 504EL dehumidifier to figure this out. The fix-it web site "Just Answers" said that it wasn't worth fixing after I described all the symptoms. Tomorrow I will go to the local LG fix-it shop and try to get a replacement to tide me over until I can find a reliable dehumidifier. Sadly, last Fall I took my 25 year old Westinghouse (made in America) dehumidifier to the dump. Even though it needed me to tune it up every year or two, at least I could fix it and it kept on working for 25 years. Good luck! enterich
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Green power button keeps blinking, won't start after pressing.
