Question about RCA HD52W58 52" TV
Shows red, bulbs out? - RCA HD52W58 52" TV
  • RCA Master
  • 1,800 Answers
The color tubs gone faulty change it
the STK 320
Posted on Jun 21, 2009
Lamp light blinking red
From your description it sounds like the lamp bulbs needs to be replaced.
You need one of these:
http://www.amazon.com/Hitachi-50VS69-Watt-RPTV-Replacement/dp/B006C58MOI
NOTE: DO NOT TOUCH THE GLASS PART OF THIS BULB. The smudges from your fingers can show up on the image projected onto your screen and make things look blurry.
Once you have the new bulb then turn off the TV and unplug it. On the back panel there is a rectangle on the left with a screw holding it on. Use a philips head screwdriver to loosen the screw then slide the rectangular panel to the left and pull it off. Inside will be the old lamp bulb. Use the screw driver again to remove the screw holding the lamp bulb in and pull the lamp bulb out (it may be hot). Insert the new bulb and then screw it back in. Place the panel back on and screw it back in as well. Make sure the screws are tight or the TV may not turn on. You can now plug the TV back in and turn it on. If done correctly this should resolve the issue.
May 07, 2013 | Hitachi 50VS69 50" Projection HDTV
I have a 50vs810 dlp. The blue and red lights flash in sequence when I turn it on.When they stop flashing the red light for the lamp is on. The yv has no volume and no picture. Is it just the bulb or does...
More than likely, it is the bulb. My hitachi 50v715 would come on(light up and show picture) 3 to 30 sec's with out the lamp indictor even lighting up. Put a new bulb in and works great. So I would try a new bulb. Look in your manual for the bulb number. Buy an original hitachi bulb they last a little longer.
Nov 05, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
sounds like a convergence board problem. a certified tv technician can check and realign convergence for you.
Jun 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red color on lcd monitor comes and goes
A red color generally means a ccfl backlight is going out,
this is the bulb itself, not the inverter.
If you want to take it apart and troubleshoot and find out which bulb (this monitor has 4) just let me know and I can give you instructions in dissassembly and troubleshooting.
if the red light just comes and goes and you can live with it, I would. It may be difficult to troubleshoot if it does not show red as soon as you turn it on.
If it is the bulb, eventually the problem will get worse until it turns on for 2 seconds and kicks off.
Apr 01, 2009 | ViewSonic VE710b 17" Flat Panel LCD...
RCA Scenium will not show color red
mat be an output driver in the clolor output circuits...or just maybe the red bulb ot gun is gone...lmao
Feb 04, 2009 | RCA Scenium D40W20 40" Rear Projection...
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Red color halo/shadowing
can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
RCA HD52W58 52" TV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
