Since you went to Outlook, I cannot access my emails. I have business emails I cannot read. Please help. Before I would just put in mns hotmail and get the inbox. Now I get the 'go to Outlook, but the page won't print out for me, just the very top of it, so I can't access anything.
SOURCE: self deleting emails
Actually they are right but they are only telling you half of the
equasion. Here is what is most likely going on. I'm about 80% sure.
Norton antivirus is a very weak antivirus system. The only thing it
catches is the common cold. Now as for outlook. Yes outlook is very
vulnerable to Virus attack. I use Thunderbird if I ever use a program
for E-mail. I use Gmail or Yahoo myself but you can continue to
frustrate yourself with programs like Outlook if you like. If you must
use antivirus to protect yourself from Micro$oft then use Avast, Spybot
1.5, and Clamwin. You will need to configure them properly to get them
to work.
There is another way. You can stop using Micro$oft products and
download a Free Operating System that does not get viruses or get
fragmented. It also comes with Thunderbird. It's called Ultumix.
If you want Ultumix do the following:
If you have a Desktop PC connected directly to the internet (not dial up) and a DVD burner I would recommend you go to www.mindblowingidea.com, click Ultumix, and give it a try by saving the Torrent Download Link. Then go to www.download.com and install uTorrent. You will also need to go to www.burn4free.com
and install it as well. Make sure to open burn4free after installing it
as well and select English. Then you may close it. Open the torrent
file you downloaded in uTorrent. After you save the .iso file to your
hard drive (this may take an hour or a day) right click on the .iso
file and click burn4free and then Burn ISO. You will need a DVD-R or
DVD+R in your DVD drive. DVD-R is recommended. After this reboot your
computer and make sure to boot from the DVD drive. You may need to
press additional keys during start up to get this to happen. You will
see a menu that says PCLinuxOS 2007. Select LiveCD and press enter
(this mode will let you try Ultumix without installing it on your hard
drive). Now it will ask you some questions about your computer like
what language you speak. You will most likely use Ethernet as your
internet. Now you will see a screen to log in.
To try Ultumix without installing it to see what it will be like click
on Owner and then type owner all lower case in the password field and
press the enter key on your keyboard. Please note that it will run much
slower than normal in Live Mode. When you install it it will run much
faster. If you try the programs on the desktop and like them you may
want to install it. We will get to that later. Open the icon marked
internet and use it to get to www.hotmail.com. Get into your e-mail. If
that works you should be happy. At this point I would like to point out
that even though this system can't get viruses or fragmentation (unless
you fill the partition over 95%) Firefox can be affected by some
spyware and or trojans. If this should occur you simply click Tools
> Clear All Private Data > check everything > Clear All
Private Data Now.
If you want to install this on your computer you can also leave Windows
on as well but you will be asked if you want to run both during setup.
Click start and log out. Now click the root account and type in root
all lower case. Click Install PCLinuxOS. Go threw the wizard and follow
the instructions. You have the option of resizing your Windows
partition and using the rest for Ultumix or erase everything and start
over. Ultumix can run most windows 95, 98, and 2000 programs in WINE.
You will also find that it can run some XP programs as well like Office
2003.
Have fun. If you still want to live with Micro$oft software reply to me
again and I will walk you threw the painful process of protecting your
computer. You will need to repeat this process I give you every 12
months or less to keep your computer running. You should also be told
that in 6 months Microsoft is planning to stop extending service to XP
users.
SOURCE: My partner deleted the microsoft
My best guess as to what your problem is, is that you need to tell Outlook what your mail servers are......... And as each Internet Service Provider has their own your best bet is to give your ISP a call and ask the what your pop3 and smtp servers are.
Then you need to tell outlook what those servers are, the procedure for that varies a bit depending on what version of MS Office/ Outlook/ Outlook express you have.
A possible way for you to contact Live would be to sign up for a free web based email such as MSN, Yahoo, Hotmail, or gmail. As these email servers are all web based and don't rely on Outlook for you to receive a message they should give you a reliable way for Live support to contact you, and a backup email account for the future ;)
Hope this helps
Dave
SOURCE: put web search in, www.hotmail.com-then
Go to www.hotmail.com then type only dawnandrobert@hotmail for the username
www - is used for website addresses
SOURCE: i cant access my yahoo email acct.
Try to install another browser like Mozilla firefox & try to open yahoo account...
SOURCE: messages in yahoo inbox disappearing
>lets check this option
>open outlook tools>account settings>select the account >click change>Advance tab>leave a copy of message on the server >apply and OK and continue with account settings wizard
>this is only applicable to pop accounts
and emails which will come after checking the option will remain on the webmail inbox
