Question about Refrigerators
I feel alot of heat coming from the center wall between the freezer and refer. Most of the heat is at the fron the of wall where the doors close. My other refrig is warm but nothing like this.
  • damas03 Jun 21, 2009
    Maytag thank you for the reply. There is no ice in the freezer, cold air is coming into both sides and actually the temps are reading at the set temps. I did notice that the refrigerant tank is really hot though. As far as the compressor motor, is there a sure way to find out if that is working correctly? Thanks again!
    President:
  • 1,136 Answers
Hi, When you can feel that heat, it is a sign the refrigerator is not cooling properly. Look inside the freezer section and see if there is frost building up on the rear panel.
Other things to look for are, make sure the fans are running. Make sure the coils underneath the refrigerator are clean. Make sure the compressor is running.
I hope this gives you some idea of what is going on. Please let me know if I can assist you further
Vic
Posted on Jun 21, 2009
  • Victor
    Victor Jun 21, 2009
    You will need to call a repairman and have them teat the compressor. They will have the gauges it takes to test it.
Replace fan motor
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the upper liner side wall in your fresh food section. So, I do not know what you have.
There are several reasons your fresh food section is not cooling:
1.) Cooling air vent from freezer to fresh food section. Find the air vent, put your hand in front of it, do you feel any air flow? This vent may be iced up or closed.
2.) Freezer cooling coils iced up - Look at the back wall of your freezer, is there frost or ice on the wall? You may have a bad defrost heater.
3.) Cooling coil fan - Open the freezer door do you hear the fan? Push in on the light switch, do you hear the fan?
Get back to me.
Peter Goodwin
Glen Burnie, MD
Jun 10, 2015 | Samsung Refrigerators
Clear water coming from bottom of refer.
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 25, 2015 | Refrigerators
Alarm sounds on fridge, not cooling
is it a bottom mount machine,freezer on the bottom?if the door doesn't close all the way and the alarm is on this could be your problem,the warm air gets in and freezes up the air ducts.look on the ceiling of the freezer and on the lite,if there's ice or like snow there the door was left open.also check the inside back wall of the freezer,touch it and see if there's any ice or like snow on the inside back wall,you could have a defrost problem or like i said before the door could be stuck open,look for frozen water droplets on your food packages or on the ceiling of the freezer,if so shut down the machine,pull out the food in the freezer and with a hair dryer heat the back inside wall of the freezer for like 15 to 30 minutes,turn it on,if you can feel cold air blowing into the fridge section you should be fine,you might have a package or i've seen people install the door draw in backwards and the alarm will go off because the door isn't closing correctly.let me know what you find and where the alarm is coming from,the freezer or the fridge side.good luck and happy holidays to you.
Dec 23, 2011 | Refrigerators
Burning electrical smell, refrigerator hot at lt side (freezer side) and at center area between doors
When you smelt this was the fan in freezer off? If so it is most likely in defrost mode and the smell is from frost melting and hitting the heater in the freezer. The hot on the sides and in the center. Is this outside the box? If so this is normal. There are coils inside the frame of a fridge that stay warm to eliminate condensation. Sometimes they shift and get too close to the wall and thats what you are feeling.
If you have any further questions please feel free to contact.
Jul 27, 2011 | LG LSC26905TT Side by Side Refrigerator
On my GE Profile side by side, the refrigerator door does not close all the way.....I have to give it a small push to make sure it is closed. Also, when the door opens it continues to swing open and hits...
you can adjust the hinges on the top of unit... make sure with the door closed you have the same distance all the way down between the two doors... if that is good there is a hinge cam that is plastic and probley the culprit here.... lastly make sure the door seal has no rips,tears or coming apart... you can take a hair dryer and reshape these if this is a older unit just be careful doesnt take alot and if heated to long will melt the door seal quickly......
Dec 31, 2010 | Refrigerators
Icemaker water line is frozen...i will remove everything and open the freezer door to let it warm up. When I chill the freezer again do I keep the icemaker arm up until the freezer is cold and then lower...
Dont leave freezer door open it will cause alot of problems. The ice maker will not call for water until the temp in freezer is cold enough. Remove the ice jam. If you remove from back of freezer it helps alot. Pull out of the back wall and remove ice be sure to put it back the way it was. Any further assistance please feel free to contact me.
Jun 16, 2010 | KitchenAid KSBS25FK Side by Side...
Alot of ice on back of freezer wall and freezer and refer warm
this might be that the door is left open or is being opened for too long. check to see if anything is holding the door from being closed properly.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
After you open and close the refrigerator on top, the freezer drawer pops open. it is now leaking water.
check to see if the fridge is tilted back a little so the top door closes with just a little shove,also if there isn't any weight on the freezer door it will pop open,put something on the door,a bottle of water that will freeze or whatever you want,it could be leaking from stuff melting from the door being open, is the water dripping from the door?the door does freeze up and will melt out if door is left open, hopefully your air ducts didin't freeze up,make sure you can feel cold air blowing into the fridge section,if not heat up the back wall where the evap fan motor is with a hair dryer the air ducts are near there and check the freezer ceiling for frozen water droplets,hopefully everything will freeze back up with the door closed.
Jan 28, 2010 | Amana ABB1927DE Bottom Freezer...
My freezer works fine but fridge does not! Any solutions?
ok check the back wall of the freezer for frost,
while your looking hold the door switch closed
do you hear the fan,
if there is frost your coil is clogged and the fan cant pull air through it
you can clean this up by turning it off for 12 hrs
but it is only a temp
if the fan is not running thats your problem
if there is no frost and the fan is working
close the freezer, open the refer upper left hand coner do you feel air.....
but if this is a maytag,you will need a
defrost circuit board
Oct 04, 2009 | Refrigerators
Swan fridge freezer-freezer dones,nt get down to temperature but fridge is working fine.if you turn up the thermostat the fridge acts like a freezer
There is a damper door that opens and closes when you move the thermostat. I would bet the door is functioning incorrectly. All the cooling of a refrig comes from the freezer and gets blown into the refrigerator compartment. If that damper door is open too far it will have constant freezer air blowing in....and if it's not open enough obviously the refrig will not get cool. Look at the upper left corner of your refrigerator, the center rear wall of the refrig or just feel around for a vent will cool air blowing out of it......Then take it apart and see if anything is broken.
Sep 09, 2009 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
