Question about RCA 32V420T 32" TV
How to open up an rca 32v432t tv
I need to take out front panel of tv to clean off switches
SOURCE:
SOURCE: RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Posted on Apr 16, 2008
jerryg50
  • 1691 Answers
SOURCE: rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Posted on May 25, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Posted on Dec 18, 2008
  • 41 Answers
SOURCE: I have a 32" RCA
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Posted on Sep 27, 2010
jhinsincity
  • 616 Answers
SOURCE: MY 2005 32INCH RCA TV MODEL # 32V432T SCREEN
Bad picture tube
Posted on Jul 31, 2011
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I have an 32 rca t.v my son has locked and won't
I got this from the manual. Page 26.
Press MENU to see the main menu.
Press CH+ or CH- to highlight preferences.
Press OK to enter the preference submenu.
Press CH+ or CH- to highlight Par. (Parental) Control.
Press OK. Enter Password will appear on the screen.
If you want to set a new code, go to steps 6-8 directly. (You can press the number buttons to enter a four-digit code. The code "0000" is the default password. If you have not set a code previously, then "0000" is the code.)
Resetting Your Password
Press VOL+ on the remote and the CHANNEL + on the front of the TV at the same time. Enter New Pwd. will appear on the screen. (You must be in the Enter Password screen when attempting this.)
Press the number buttons to enter a four-digit code. The code will appear on the screen as you enter it.
Press OK to save the code.
Press MENU repeatedly to exit the menu or the menu will automatically disappear within a few seconds if no buttons are pressed on the remote control.
If you need more, get the manual here:
http://www.retrevo.com/support/RCA-32V432T-TVs-manual/id/402ci372/t/2/
Pages 25 through 30 are all about lock and channel/show blocking.
Jun 05, 2012 | RCA Televison & Video
Rca turns itself off and on and scans thru all the channels
I have an easier solution, First I want to thank those who posted the solution that the problem is on the small switch board mounted right behind the switches under the picture tube. I figured that might be where the problem was but it's better to to see it confirmed. I thought the problem was more complex like maybe an IC chip got zapped or something but there are none on that board. Only 6 switches, the infared sensor, 1 capacitor and some resistors. I am convinced that in my case at least the problem is caused by humidity. It happened last year constantly durring humid weather in the summer and only a couple of times over the winter when the air is dry and cooler. I did figure an easier way to disconnect all the switches without unsoldering. After you remove the board, flip it over to the solder side and see where the wires connect. You will see them labled GND - KEY - +5 v - LED and IR. The one you want is labled KEY. You will see on the other side this wire is second from the end . Just separate the wires a bit and cut it. That's it. Just be sure it is the one marked KEY. This wire goes thru a series of resistors and the switches and nothing else. Just cut that one wire and put a piece of tape over the cut ends and thats it. it's a lot easier then unsoldering all 6 switches. And if you do decide at some point later to replace the switches, it's easy to resolder the wires and tape it. I did it this way and my TV is working perfect. I was done in ten minutes. You can only control the TV with the remote but so what, thats all we use 95% of the time anyway. I hope this helped you.
Sep 01, 2009 | RCA 32V420T 32" TV
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca tv model 32v432t
Nov 18, 2008 | RCA 32V420T 32" TV
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Nov 08, 2008 | RCA 27V530T 27" TV
Rca 32v432t
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
RCA 32V432T television ,Turns on and off on its own and runs through channels continuously
The problem is most DEFFINATELY the control board behind the user buttons.
You have 3 options to fix this...
1. Replace the new board completely (no garuntee your getting a "new" part).
2. Replace the tack switches (requires soldering and patients [alot of them]).
3. Remove the board and snip the one wire marked "Key". I didn't snip it so much as correctly pulled the wire out of the plug itself. By removing that one wire from the board you disable just the buttons. You still have complete use of the remote. Who the heck walks over to the TV these days anyway!?!?
Dec 04, 2007 | RCA 32V420T 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
RCA 32V420T 32" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
