2000 lincoln ls cranks over but wont start. i checked the coil pack resistance and they all read the same. i even put new spark plugs in the car.
Car not starting or turning over indicates towards multiple possibilities.
It can be issue with battery or weak battery. But if battery checks out ok, then
it can be starter issue or faulty alternator or problem with low fuel pressure
or no spark at spark plugs due to dirty spark plugs or faulty
ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
A car that cranks over but doesn't start, in many cases will be due to a bad fuel pump, a broken timing belt, an inoperative cam sensor or crank sensor. Also these problems are related to faulty spark plug. Check the spark at spark plugs when you start the car. Do you notice any spark. Actually you should see. If in case there is no spark then it's a spark plug problem. Also the coil pack gives power to spark plug. So check the voltage at coil pack. It will show 12 volt. If there is no voltage noticed at coil pack then its faulty coil pack that has to be replaced. If all the possible options checked out ok then check the car starter. The starter gets power from battery to start the car. If the starter is faulty then it will not let the car to start. Also check and confirm that there is fuel in the car. If its very low fuel then in some cases this causes the problem. Also check and confirm that fuel pump is functioning properly and the fuel filter is not clogged. One of the easiest ways to check for a fuel pump related problem is to spray a little starting fluid into the air intake while trying to start the car. If the car starts momentarily, then there's a good chance the fuel pump is not working or the car is out of gas. You can also listen for the fuel pump's humming sound when the key is first turned on. Also if a inoperative fuel pump is suspected, a good technician will always check to verify there is power and ground being supplied to the pump, to eliminate the possibility of a bad relay or electrical issue. Fuel pressure can be checked with a pressure gauge and if there is pressure, pulse can be checked at the fuel injectors in several ways including the most common, with the use of noid lights. If the injectors don't have pulse the engine won't start. ---------- This troubleshooting tips will help you to solve the problem. Thanks. Helpmech.
