Question about Konica Minolta DiMAGE Z20 Digital Camera
USB Wont Connect
When I plug the USB in the Camera and the computer it comes up and intializing USB Connection, then after about 4 mins just turns itself off?
Is this a problem with the camera or the cord, and if the cord where can I buy a replacement for it.
  • fwscreen Jan 05, 2008
I have the same problem, nobody can give me a answer either.
Posted on Feb 10, 2008
I am trying to connect my Leica Dicomar 12x official zoom 4.0 mega pixel still picture recording camera to my MacBook into iMovie and when I plug the USB from the camera into my computer it is not...
According to Leica there's a particular order you have to do things in:
1. Connect your Panasonic videocamera to your Mac using the USB or FireWire cable that came with the camera.
2. Launch the iMovie application, then turn on the videocamera and set it to "Import" or "PC Connect" mode.
Nov 02, 2017 | Leica Cameras
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Wont connect to the computer anymore
Are you deeply attached to a USB connection? The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, or you can continue using whatever software you've been using.
May 10, 2010 | Nikon D40x Digital Camera
Cybershot wont connect to the usb
are you connecting to the same USB slot you use to connect before?
Check from the BIOS of your computer is USB port is enabled.
or go to My computer then right click, choose Properties, then select Hardware > Device Manager. Look for the Universal Serials Bus Controllers, then expand. Find the usb port right click on it> select disable.
Aug 21, 2009 | Sony Cyber-shot DSC-T100 Digital Camera
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
(from Sony Website)
Mar 19, 2009 | Sony Cameras
US doesn't stop blinking!!!
Heres how i install my modems
1.Turn off all equipment
2. Take an ethernet cable going from the modem, and plug it into the ethernet slot on the computer.
3. plug in the modems power and give it 1 min to power up.
4. Power up your computer and see if it gets connection.
1.Go to the control pannel and look at internet connections.
2. Look for your connection (LAN), and see if is connected.
3. If it isnt connected than it is a problem on your ISP's side.
For other support
1. Call your internet service provider for help.
2. Call the customer support line for the modem.
May 09, 2008 | Linksys EtherFast Cable Modem with USB and...
JVC Everio GZ-MG37u Cant Connect to Pc
how to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Feb 24, 2008 | JVC Everio GZ-MG37 Camcorder
I cant put pictures onto computer?
you have several options.
1. see first what operating system you computer runs.
if it is vista or mac, it will be recognized as unknown device,
look for SSCAM100 or DCIM folder. you will then see the camera files in that folder.
2. you should also download the cd driver, the cd that comes with the camera, to your PC. this will help the connection be proper.
3. if you're using desktop, try to connect the camera at the back of your tower. look for a USB port at the back of the tower and connect USB cord to it.
4. make sure you're using the proper USB cable, the cable that comes with the camera. for your S630, it is USB cable type 2.
5. also, make sure before you connect camera to PC, camera is turned off, when the USB cord is properly connected, that is the time camera should be turned on.
6. when unpluggin the camera to PC, make sure that you are safely removing the device from the PC so you will not have future connection problems.
hope my suggestions work for you.
Jan 06, 2008 | Samsung Digimax S630 Digital Camera
What's up with my camera
You will probably have to go into "My Computer" and find your camera in the "Devices with Removable Storage". It should be there, otherwise, try plugging it into a different USB jack on your computer, if you have one.
Dec 06, 2007 | Samsung Digimax S630 Digital Camera
first, open Windows Explorer and then search for the drive letter that Windows has automatically selected to be your camera's memory card. If you cannot find it (remember to right mouse click over each letter to see a short description). Once found on Windows Explorer, double mouse click it and then search all camera memory folders for the video files. You can then right mouse click and copy each file and then past (rt. mouse click select paste from pop-up sub-menu) each file onto your pc hard drive.
Aug 01, 2007 | Samsung Digimax S500 Digital Camera
Konica Minolta DiMAGE Z20 Digital Camera Logo
74 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
