Computer Brands with dell
Can any brand all in one printer work on a dell computer system? My printer do longer catches the paper properly, therefore preventing my documents to come out clear and straight. I have had this system for about, if not 5 years now. The system's tower is heavy and bulky. I was thinking of purchasing another printer, perhaps from staples or a local electronic store to catch a better bargain. I have a Dell system. Will another brand AIO printer work just as good with my system?
  • 130 Answers
Yes as long as driver software downloads or disks are available for that mod. and the operating system you have
Posted on Jun 21, 2009
Yes off course, any printer works with dell. just u should check one thing tht your operating system is compatible with the printer.
  • 1,800 Answers
Try any hp ain or canon pixma"s its a good gear though
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Problems getting printer to respond after clearing paper jam
hi try this http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Tip
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer: https://youtu.be/4nGBQ0H1RQw
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
Tip
How to maintain your ink-jet printer
In the printer market there have thousands difference brands and models ink-jet and laser-jet printer, how can we eleminate their trouble to the minimon and extend their lifetime as long as we can. The paper tray for the ink-jet printer most are open top style, therefor very easy to catch dust and other cbject and cause paper jam, paper skew, paper rinkle, some cases are easy to remove some don't,when you have those case happen, the first thing you have to do is check the paper tray inside of the bottom , looking for somethings it not belong to, then clean up the paper feed roller with rubbing alcohol. Now how can we prevent it happen, the way is when finish printing use something to cover the tray. when paper jam occure, remenber, never pull the paper opposited way, you have follow the direction let he paper go forward, otherwise you going to damage the paper senser.
How about laser printer, the laser printer it's structure much stronger than ink jet s the cost much higher too, but their maintainence much easier, when it have paper jam occure, commonly replace paper pick up roller and paper stop roller, if you hear noise from back of the machine, 90% the fusing unit have problem, if the noise come from front, the problem almost in cartridge, the cartridge, here , I like to give you advise, use brand name cartridge better than generic one. because, too much manufacture, skill all difference as well as quality all difference, be careful, be smart !
on Dec 10, 2009 | Office Equipment & Supplies
My Dell AIO 924 printer will not feed paper.
1.Check inside the printer to see if you have the ink properly installed.
2.Make sure you don't you re-use papers that you have already used.
3.All papers have to be perfectly allined.
4.Check the connection wires between the computer and the printer.
5.Scan your computer with a security system to catch and eliminate viruses,tracking cookies etc.
If all else fails I don't know what to say
Jun 24, 2012 | Dell 924 All-in-One InkJet Printer
My lexmark printer says paused and i cannot print. this happened after i changed the cartridge
Did you buy the proper cartridge for the printer or did you purchase a generic brand one? I've tried the generic (and therefore cheaper) brands before and sometimes the printers are unable to read/use them even though it fits when you install it.
Jun 20, 2011 | Office Equipment & Supplies
Dell v305 printer paper is not going into printer properly. seems to be pulling down crooked.
you have to make sure the printer paper is pushed down all they way. it needs to be able to catch the whole piece. i have the same printer, same problem it seems to crumple the paper when it pulls it down if not fully pushed down.
Dec 21, 2009 | Dell V305w All-In-One R840635AU InkJet...
My paper jams 1815dn all in one
I have encountered this phenomena before on other and better brands ( nebver buy dell anything!)
having said thyat perhaps it is the grade or brand of paper you are using, some printers even inkjets cannot handle sime grades of paper. So try to get different paper loaded and see if that fixes it
Jun 23, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
