Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
TV powering on and off every few minutes
It did it for a short while a week ago and would power on and off every couple minutes. I turned the tv off for a bit and when it came back on everything was okay. Just turned tv on and it is continuing to do this. I have a Sony WEGA hdtv.
Last time the bulb went out the picture just got super dark. Could this be a sign that we need a new bulb? It has been about 2 years since our last bulb was bought. Thanks!
    Problem Solver:
  • 4 Answers
Yes, this is common in Sony's when the lamp begins to fail. You may even see a small sulfar looking burn on the lens of the lamp (that is what causes the pic to go dimmer). Remember not to touch the lens when replacing new lamp.
Posted on Jun 23, 2009
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
TV wont come on
Most likely cause would be a blown fuse on the power supply if you are getting no lights on the front, no response from the buttons, and no warmth from the back of the set. First check that not only is the power socket in the wall working, but also that the plug on the TV power cord is not faulty or distorted so it doesn't make the circuit when plugged into the wall, also if it has a fused plug, check that. Then if you feel up to taking the cover off, make sure the set is unplugged and leave it for a few minutes first. take off the back cover (usually a few screws around the base of the set, but it should be obvious) follow where the power cord enters the box, and about the first thing it should connect to is likely to have a fuse. Probably a couple of metal spring clips with a glass tube type fuse sitting in them. The fuse should have a rating stamped on it and you should be able to get a replacement at most hardware stores, but make sure you get the same type as well as rating. If a replacement fuse doesn't cure the problem then the next thing to suspect would be the transformer and rectifier circuit - the fuse should have protected these, but sometimes it doesn't work that way. If you need help checking these then please ask again, but I suspect the fuse is your problem. Hope this helps you out, please ask again if you need more info :)
Mar 24, 2006 | RCA F32450 32" TV
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
