Question about Alpine CDE-9845 CD Player
AUX to work
I need to find the AUX so i can play my mp3 or ipod but i cant find it please help?
  • alex_maya21 Jun 21, 2009
    yea but the thin is that i connected it on the back already but i used the cable that had the red and white plugs you know? n the other side was just black n that one fit the mp3 fine. so i was wondering how you can get it to play now, like does it have to be on the radio or cd?
  • 655 Answers
Hello alex_maya21,
The AUX input on your CDE-9845 is on the back of the receiver. To use it, you need a cable with the appropriate connectors on each end. The receiver end needs to be a standard "mini plug" and the device end needs to match the output connector on your mp3 or iPod. There are many commercially available cables that you can plug in and run the device end under the dash to a convenient location. Almost any car audio retailer will have the correct cable or you can order one online from www.crutchfield.com.
Hope this helps.
Posted on Jun 21, 2009
  • Ronny Brite
    Ronny Brite Jun 21, 2009
    Hello again alex_maya21,
    The connectors you seem to be describing appear to be RCA type and are preamp outputs, not inputs. The AUX connector is a single small round jack just to the left of the wiring harness connector.
    After you have the MP3 player properly attached, you need to set "AUX IN ON" and then select "AUX" by repeatedly pressing the "SOURCE/POWER" button until the display reads "AUX.
2 Suggested Answers
  • 69 Answers
SOURCE: cant find aux conection for ipod function
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
http://www.bestbuy.com/site/olspage.jsp?skuId=7710943&st=ip+bus+aux&lp=4&type=product&cp=1&id=1138086437269
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer http://www.google.com/products/catalog?hl=en&source=hp&q=pioneer+ipod&um=1&ie=UTF-8&cid=9877805020289826524&ei=_vPKSpzyKYe4NrzrpPMH&sa=X&oi=product_catalog_result&ct=result&resnum=1#ps-sellers
Posted on Oct 06, 2009
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
My daughter has an Iwantit ipod speaker model IW900 and it works/sounds fine with her ipod usind the dedicated ipod connector. On the the back of the speaker there is an Aux in socket. She would like...
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Aug 16, 2010 | Audio Players & Recorders
How do i connect my ipod to the KD-R301
you need a 2.5mm jack lead connect 1 end to your IPOD/MP3 player and the other end to the AUX IN on the front of the head unit then select AUX on the head unit and play on the IPOD/MP3 player and it should work
Tom
Jan 16, 2010 | JVC Car Audio & Video
Hi do you know if the wharfedale ics 182 can play an ipod
You need to plug the iPod into the Aux socket, its on the front bottom right corner. Then you can switch by pressing "Mode" between playing either the CS - USB - SD - AUX.
To play iPod, select the "AUX" option.
Nov 03, 2009 | Bang and Olufsen BeoSound 2 Companion MP3...
Only 3 speakers play with ipod all other is ok
Are you playing your ipod through the stereo with a cable in aux mode? If so check your fader and balance settings when in aux.
there would be no other reason except for speaker wiring check and make sure there is no auxiliary wiring that may not be hooked up.
if it's not settings, then it's wiring, unless your stereo has an internal problem in the auxiliary circuit.
May 27, 2009 | Apple iPod MA446LL/A MP3 Player
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Playing my ipod on AUX mode????!?!?!?!?!!!!??
HELLO, ON THE IPOD BOX ARE SEVERAL NUMBER CODES. THEY HAVE TO BE SET TO THE RIGHT NUMBERS ON OR OFF BEFORE THE FACTORY RADIO WILL READ THE BOX. ONCE THE CORRECT NUMBERS ARE SET FOR YOUR VEHICLE THE AUX BUTTON WILL WORK JUST FINE. IF YOU DON'T HAVE THE BOOK WITH THE CODES IN IT. JUST COUNT THE WIRES ON THE ADAPTOR AND THE LOCATION OF THE PINS THEY CONNECT TO. THEN PUSH ONLY THOSE PINS UP IN THE ON POSTION. GOOD LUCK!
Jun 07, 2008 | 2003 Chevrolet Avalanche
Usb mp3 plyer
I will need more information, what cable are you using to "plug" it in. My DEH P4800MP does not have a USB jack on it any place.Please give more information. I will be glad to help you then.
Sorry,
Scott
Apr 23, 2008 | Pioneer DEH-P4800MP CD Player
Alpine CDE-9845 CD Player Logo
613 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
