Question about Bosch Evolution 500 SHE45M05UC Stainless Steel Dishwasher
Brand New Bosch Stopped Working On First Use
Dishwasher worked fine when the installer tested it. Later that night, I used it for the first time to do a small load (regular wash on half load feature). When I checked the machine the next morning, my dishes were soaking wet, there was about 2 inches of water in the bottom, and I can't get it to power up
    Sergeant:
  • 212 Answers
Need to make sure no breakers have tripped if not then replace operating thermostat. if it is only a few days old you should be able to get the dealer to cover service call and labor
Posted on Jun 21, 2009
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
SHE45M05UC Bosch dishwasher
open the help booklet and follow the instruction if it is not working you can get replacement.
Dec 11, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Hi We have a 1 yr old Bosch dishwasher SGS45C02GB-06. It's stopped working for the second time in a year. It stopped mid-cycle and the water is not draining away or being pumped away; although you can...
Did you install the high-loop for the drain hose? If not, you need to pull out the dishwasher and make sure that the hose is not lying below the pump at the bottom of the dishwasher. This will usually fix this problem.
Jan 05, 2011 | Bosch Dishwashers
We have a new Bosch SHE55M15UC. It worked fine for 4 months, now it leaves a dirty looking film over all the glasses. A service guy came buy and said he tested it and everything is working fine. He said...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Nov 17, 2010 | Bosch Evolution 500 SHE55M05UC Stainless...
No question that it is a warranty problem, you shouldn't consider doing anything on the machine yourself at this point.
After the warranty is dead and it fails, c'mon back and you will likely find someone to help. It is good though, that we are forewarned about Bosch-
Jun 21, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher worked fine last night, this morning it is not working
In some supply systems, there is a safety valve ( commonly referred to as a shuttle valve) that has a small ball bearing that blocks the water from flowing if a water line bursts.. This is supposed to be a safety feature to prevent flooding but can be an annoyance if that ball moves and blocks water flow from coming in.
That, or your water inlet valve may be the prime suspects for this problem..
Hope this helps,
Regards,
Rick
Dec 13, 2008 | Bosch Dishwashers
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Won't stop pumping
H android1968 and danimaldds
The reason it keeps running is because there is water in the pan under the dishwasher. firs this to do is shut the power off, then take the kick plate off, remove all the water that you can. this should fix it , if it happens again there might be a leak from a seal or from suds. hope this helps
brent
Jul 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Evolution 500 SHE45M05UC Stainless Steel Dishwasher Logo
150 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
