Question about Refrigerators
Water keeps accumulating in the crisper drawers and bottom of the refrigerator.
    Genius:
  • 1,269 Answers
There's probably an air leak there. Clear the ice-clogged drain in the freezer.There is what you called a condensation drain hole that is located directly behind the freezer. You must clear the ice build up there. That will solve your problem.
Posted on Jun 21, 2009
FRIDGE IS LEAKING LOTS OF WATER UNDER THE CRISPERS
Good Afternoon Friend,
I understand your Frigidaire refrigerator, model# GLHT184TJ, is leaking water underneath the crispers. First, make sure the door is closed as well as you are not opening it frequently or for long periods of time. Secondly, make sure all foods and containers are covered. Lastly, make sure that all vegetables have been dried, if you have washed them, before storing them in the crisper drawers. All of the above can cause moisture inside your refrigerator, which can accumulate at the bottom of your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLHT184TJ Top Freezer...
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Water is accumulating in the bottom of the refrigeratior below the crisper drawers
check and make sure the drain tube is not frozen over and is free and clear to allow the water to drain in the drain pan.
Mar 19, 2010 | Refrigerators
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Fridge problem
There is a drain, usually at the bottom of the refrigerator compartment. Pull out the bottom two drawers and see if there is a drain. It is usually in the very back of the inside compartment. Make sure it is not clogged. Usually, this is the problem.
Oct 18, 2008 | Frigidaire Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
