Question about Ingersoll Air Tools & Compressors
Help with 1967 Ingersoll Rand 223 30T Compressor
I recently acquired a 1967 223 30 horizontal compressor which has two pumps, two 1 hp 3 ph motors. the pumps turn freely but need new gaskets. there is some type of filter/separator/dryer??? which seems to have been interconnected on both pumps??? I am not able to locate a manual, any ideas or suggestions?
  • 5 more comments
  • ellisonsc60 Jun 23, 2009
    In the process of replacing the 3ph motors and getting everything cleaned and re connected. The pumps work well, just need to figure out how to connect the multiple steel 1/4" tubes which come out of either a dryer or separator of some sort.
    I believe that it is a duplex with two pumps, two motors etc... One is set to shut off @ 90 psi and the other at 95 psi, all I can figure out is that one works as a primary and the other is a back up which turns on if the first can't deliver enough air??? My main concern is to connect the lines coming out of the separators properly. When the unit was removed the lines were just clipped and therefore I have nothing to refer to. I really do appreciate your time and assistance, by the way. I have removed the top of one of the pumps and it is clean inside, the piston rotates freely and creates good pressure on the upstroke and sucktion on the down stroke. I don't know much about compressors but this one is built very well, everything is heavy duty.
  • ellisonsc60 Jun 24, 2009
    Here is an image which may help. The small lines coming out of the separators are 1/4 and the large one is 3/8. There is also a 1/4 inch connection in the bottom of the tank.
    In the picture below I have two question marks, yellow and blue. The 3/8 (yellow ?) is the inlet, I hate to sound ignorant, but where does this line go to? The tank?
    Second line 1/4 (blue ?) scavenger where does that line go to? Do the 1/4 inch go to the 1/4 output at bottom?
  • ellisonsc60 Jun 26, 2009
    I believe that we are closer than ever. I am waiting for the gaskets and have obtained a single phase motor... still looking for a second one. I have removed the pumps and motors from the tank assembly and my son wire brushed and painted one pump and we plan to do the other one today. A friend down the road is going to sand blast the tank assembly and paint it with some left over automotive paint (unknown color) the I plan to get it assembled and have at least one pump running with the motor I have. I located a picture of a compressor that has a similar layout which I am attaching with another question for you. What is the horizontal pipe (appears to be a 2") that runs the length of the compressor? Mine has the brackets but no pipe.
  • ellisonsc60 Jun 27, 2009
    Sir, rest assured that a picture will follow when completed and I will send some progress pictures as well. Here's the first pump after my 15 year old helped wire brush and paint it (University of Tennessee, Knoxville colors) The other pump is getting a Duke University paint Job (his team) and the tank is yet TBD but one daughter is a UNC Tarheel and the other a NC State Wolf pack fan. So the paint job will definately be crazy. Camera battery is dead so I will send the picture in a bit.
  • ellisonsc60 Aug 25, 2009
    I have it running, a little soapy water revieled a few very minor leaks is a few of the fittings which I plan to resolve with some pipe thread putty. Have pics but can't remember how to post them.
  • 76 Answers
Wow does it still make air
Posted on Jun 22, 2009
Testimonial: "Very helpful, quick responses to questions and good advice."
  • 5 more comments
  • alex MACHELL Jun 23, 2009
    well it is a separator keeps the oil out of your air lines inlet would be on the side at a angle to create centifigal force for removing oil from air then the separator has its turn at removing the oil and your out put will be on top with a minimum pressure valve now there should be a smaller out put on top that goes back to the inlet on the air end that is your scavenger valve it sucks up any oil that gets past the separator the two pumps thing is strange though are they on a lead lag circut or do they work in tandem any way you look at it they should go to the same inlet on the side
    how many lines come out of the top and how many go in the side and if you could tell me the sizes of the lines and there orientation example 1/4" out of top 3/8" in the side i should be able to tell you what is what also see if you can find a patent # and google that # goggle has a site just for patent #s that may provide you with a exploded view print
  • alex MACHELL Jun 24, 2009
    well the 3/8 " is your inlet and the 1/4 inch on top is the scavenger to **** up any oil that has gotten through your crank case at the bottom produces a vacum tha pulls out of the seperator and off the head so your bottom lines are out put and water drain i do not know which is what get up and running and trial and error just keep all lines to the crank nice and tight when you do have it up and going after a few hours when it has run nice and hot you need to go back over all the bolts retighten every thing just like a head on a car motor i would email the manufacturer also see if they can help i have found help that way before and look for any patent # and google patent search the # it may have some exploded view prints good luck
    i think both yellows are output one may went to a machine the red is auto drain for water and the blue is the scavenger the crank case creates vacum and pulls of any oil that got into the head this what it looks like to me the red is not attched to the crank case right that is the way it looks to me i would use bottom right for air output and bottom left as a manual drain put a brass valve on it the first time you fire it up open all lines except the ones connected to the head and slowly close lines as it builds pressure and make sure you have a good pop off valve in case you build to much pressure
  • alex MACHELL Jun 26, 2009
    how goes your compressor did we get your problem solved
    that looks like the air output to me that is a unusual comp. design but it looks like it may tie in to the out put on the other pump and the larger pipe may be acting as a dirt leg because it has a drain valve on the bottom of but dirt legs are usually run off a tee with a cap on it they are meant to trap dirt and water so it does not end up in your tool this is a big concern for painters i would like to see a pic. of the end result of your labor if you dont mind
  • alex MACHELL Aug 25, 2009
    WONDERFUL I AM GLAD THAT YOU GOT IT ALL WORKED OUT AND THAT I COULD BE HELPFUL TO YOU
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I want to take to my home but I only have single phase 220, what can I do.
You can build or buy a single to three phase converter....
http://www.metalwebnews.com/howto/ph-conv/ph-conv.html
If you want to buy then just do a search and many will come up...
You size them by amp. draw... the amp. draw will be listed on the motor nameplate...
heatman101
Feb 04, 2011 | Ingersoll Rand - Rand Type - 30...
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
Motor seems to work but doesn't turn the pulley doesn't sound like it normally does
I have a Ingersoll Rand Compressor model# H15T4 and it constantly pops PRV. What do thing is the problem. Thanks.
Sep 05, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Motor pulley for an old Ingersoll Rand type 30 compressor
Here is a link to Ingersoll-Rand (compressed air division) where you can find a local distributor. I think a call to a parts tech might provide the original motor sheave outside diameter and belt size (I'm suspecting "A" or "B" size).
http://www.ingersollrandproducts.com/contact/air/index.aspx
With that info, here is a link to a good industrial source for your new motor sheave (McMaster-Carr):
http://www.mcmaster.com/#v-belt-sheaves/=3fwz7b
Their prices aren't so bad.
You may also have a local industrial sales in your area.
I hope this helps you... Nice compressor!
Sep 01, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Air Tools & Compressors Logo
463 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
