The rubber around the door tore and the washer leaks bad.where do i find that part.
    Sergeant:
  • 212 Answers
Check with local appliance dealer like lowes, home depot or whatever. the part is called a bellow or door diaphram
Posted on Jun 21, 2009
Why does he3t leak after being overfilled
you need to remove the panel so you can see where it is leaking. if this is a front loading washer then check the below seal between the door and the tub. my son overloaded ours and the rubber seal tore and I had to replace it.
May 26, 2014 | Washing Machines
A piece of the rubber circling the door opening tore off
that rubber is part of the bellow that seals the opening to the drum. if it is just a small piece that tore then u might be ok. if it is leaking from the door or underthe washer then u will need to replace it. I have whrillpool and the bellow for mine was $85
Apr 07, 2014 | Miele Novotronic W1918A Front Load Washer
Washer is leaking from door, the other day the rubber gasket between door and tub came off during use..we put it back on, but it still leaks
It sounds like you have a hose leaking.You can check the hose leaking by opening the washer door & inspecting the rubber boot that goes around the perimeter of the tubs. It is secured in place by two clamps.In order to check if the leak is underneath the washer tub you will first need to disconnect electrical power to the washer.Remove the three screws securing the toe panel to the front of the washer and remove the toe panel by lifting slightly and pulling forward.
Hope this helps.
Shane
Mar 08, 2011 | Kenmore HE2 Plus Front Load Washer
The wire around the rubber seal on my bosch washer
This video will show you how to change a door seal on this Bosch WFMC2100UC washing machine
Jan 01, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
AWM 8143 front loader- rubber door needs to be replaced
Yes,it is called a bellow.If the tear is small enough and just on the front rim of the seal try gluing it with super glue,it will get you by till you can get it replaced.
Sep 07, 2009 | Whirlpool AWM8143 Front Load Washer
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frigidaire front load washer model FTF2140ES2 that will
Jan 20, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Gasket around the door
HAVE NEW DOOR GASKET, HOW DO YOU GET FRONT OF MACHINE OFF?
Jan 30, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
