My son died and I have his computer. When I hook it up the keyboard doesn't light up and the monitor says no signal analog. What is going on????
It seems tht CPU is dead, or there may be some fault in the hardware inside it. you seriously need to call a technician for the troubleshooting.
Posted on Jun 21, 2009
My samsung monitor is just black, and the light keeps flashing, it's in analog and i cant see a picture.. what should i do?
First, be sure to check the data cable which runs from the monitor to the computer. Verify it is connected. If this does not fix the issue, then the problem is the result of one of two things:
1.) Your monitor died and needs to be replaced. You can check this by plugging the monitor into another computer. If it works, then the issue is not with the monitor and you will want to move on to #2 (below). If it doesn't work, the monitor needs replaced.
2.) Your computer is not sending a signal to the monitor. This is an issue with either the video card or motherboard (most motherboards have the video card built right into them). You can install a stand-alone video card and see if that solves the issue, but chances are you'll be having another motherboard installed (as well as having to have Windows reinstalled). If you have never done this, I would recommend a computer shop.
I hope this is helpful and best of luck!
Sep 21, 2011 | Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Flatron monitor
You need to check the monitor cable if it is correctly connected to the motherboard port. If the analog display or no signal it means the monitor cable should bot connected. If you have a video card in your motherboard you can plug your monitor cable to the external video card.
Oct 03, 2009 | LG Flatron F700P 17" CRT Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
I have a old computer (Dell) and a new flat screen (Dell) i hooked them up and the screen is black (won't work). It's a digital screen and a analog computer does this make a difference?
Not at all - as long as there is a VGA connection (analog) for the monitor, you're fine. Make sure that if you have a video card that you set your bios to automatically send the video signal through the card (where you'd hook your monitor cable to).
In some cases, if you have a video card, (and you're connected to the VGA output from the motherboard), the signal is bypassed and trying to go through the card automatically. If there is no card, disregard this last paragraph.
Apr 06, 2009 | Dell E193FP 19" LCD Monitor
Blank screen
When you say "When I turn on the computer the monitor acts like it is getting no power", do you mean the light on monitor doesn't come on or it does and it states it has "No Signal"? If it says no signal then it is receiving power just no signal from computer. What kind of connection is it? Digital(white) or analog(blue)? Is the keyboard wireless or is it PS/2?
If the keyboard isn't wireless and you're plugging the monitor in correctly I would say it's a power supply issue. Try changing the outlet you're using and/or bypass the surge protector to plug directly into wall.
Jun 24, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
