Need to reset the modem.
Cannot locate the reset button
If u need to reset there is no such button for that.
just remove the power code and then attach it again after 2 min.
reset done.
Posted on Jun 21, 2009
I forgot my password
Reset the modem by removing the power cable from the back of the modem for a full 30 seconds and plugging it back in.
This is sometimes referred to as "power cycling" the modem, and is a good way of clearing network timeouts and other problems that can appear on modems that have been running continuously for some time.
Reset the modem by unplugging the power cord from the electrical outlet or surge protector into which it is plugged.
This is a good alternative to removing the power cord from the back of the modem if it is difficult to get to the modem because of its physical location. Count the full 30 seconds and plug the modem back in to complete the reset.
Reset the modem by pressing the reset button the back of the modem.
The button itself is recessed into a hole to prevent accidental resetting, so you will need a pen or some similar thin utensil that can fit inside the hole.
Press the pen into the hole until you feel the button depress and then let go.
This is sometimes called a "hard reset" or "hard reboot," as this will restore the modem to its factory default settings
Hope this helps
Sep 25, 2012 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How to reset modem to default settings
Hi Good day!! i hope this method will help you
1. Find the manual for your cable or DSL modem. Although the basics of these types of modems are the same it never hurts to have the manual available for the particular piece of hardware that you are going to be dealing with.
2. Look up what the procedure is to reset or reboot the modem. They will list what the procedure is for performing a reboot or reset of the modem.
3. Turn off the computer if you have no manual and need to perform a reboot or reset of the modem. It is best that the connection to your computer is severed before you change anything on your modem.
4. Look at the back of the modem. There should be a tiny button or hole in the back of the modem that will be labeled reset. Typically these button need to be pressed for a minimum of 10 seconds to reset the modem. This will reset the modem to factory defaults. You will need to reset options just as if it was a brand new modem being installed.
5. Press and hold the button down for one minute. This will make sure that it has a chance to reset. You will need a small pin to put through the hole. Usually you can straighten one leg of a paperclip and this will work for the tool you need. Just beneath the surface of the back of the modem there should be a small push button that you can depress with the paperclip.
6. Allow the modem to reset itself and then remove the power plug in the back of the modem. Keep the power off for at least one minute and then return the power plug to the back of the modem and wait for all the lights on the front of the modem to come back on and stop flashing.
7. Restart your computer and check that all the options are set correctly on your modem. You may need to call your Internet provider and check which settings need to be changed from the factory defaults. They can walk you through how to make these changes. After this, your connection should be back and you can reach the Internet.
Thank you for using FixYa
Nov 09, 2010 | Arris SURFboard® SB5101 Cable Modem
Router not working
JUST TRY Resetting YOU ROUTER
  • Unplug or turn off your router
  • Locate , on the back of your router, the small button that reads Reset
  • Press, and hold, the Reset button down for 30 seconds.
  • Wait for your Power, WLAN and Internet light to turn on. (On the router)
  • Plug in or turn on your modem.(if it is separate from the router)
  • Open your web browser to see if you have an internet connection. If you still don't have an internet connection you may need to restart your computer.
Apr 11, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How to reset moorola modem sb1520 surfboard
hi, to reset the modem follow these steps.
step 1 : Turn the Motorola Surfboard SB5120 Cable Modem so that the back of it is accessible to you. There's no need to disconnect any of the cables.
step 2 : Find the "Reset" button on the modem. It's a small recessed button located between the USB port and the cable outlet.
step 3: Use a pointed instrument to push the button. Hold it for 10 to15 seconds to allow time for the modem's indicator lights to go off.
step 4 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
step 5 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
Nov 22, 2009 | Arris SURFboard SB5120 Modem
NEDD TO REINSTALL VERIZON DSL BUT LOST
You have to connect to the computer to the modem directly. Turn off the firewall program. There should be a reset button located on the back of the modem. Push and hold the button for thirty seconds. After the thirty second the modem should reboot. After the modem reboot, loard any browser and the verizon online should take on it own.
Sep 28, 2009 | Westell Wirespeed LiteLine 6100...
How do you reset the modem?
To reset the Router:
1. Using the tip of a ballpoint pen or unfolded paperclip, press and hold the Reset button located on the bottom of the router. The pwr LED will blink red once, indicating that the reset has begun.
2. Continue depressing the Reset button for four seconds or until the pwr LED begins to blink alternating red-to-green.
3. Release the Reset button
Aug 27, 2009 | Siemens SpeedStream 4200 (13A4200001)...
SL2-141 modem reset switch button
in most of the modem reset switch is inside the modem they only give a whole through which you can insert a pin or something to reset it. It is at the centre back side of the modem.
Jun 17, 2009 | Siemens (120-5830-001) Modem
I can´t reset the modem D-Link 2320-B, I am trying
You can restore the unit to factory setting by pressing the reset button. It is located inside a small hole on the back of your router between the LAN and DSL connections. You'll need a pin or very small screwdriver to reach the button inside the hole.
May 08, 2009 | D-Link DSL-2320B
Lost user name and password for configuration manager
If you forgot your password, you must reset your modem.
Note: This process will change all your settings back to the factory defaults.
To reset the modem:
Step 1 Locate the Reset button on the rear panel of the unit.
Step 2 With the modem powered on, use a paperclip to hold the button down for 10 seconds.
Step 3 Release the button and the modem will go through its reboot process.
Step 4 Wait about 30 seconds to access the modem.
After restart the modem you can use default username and password (admin/admin)
For further help you can check the link below
ftp://ftp.dlink.com/Broadband/dsl2640B/Manual/dsl2640B_Manual_100.zip
Mar 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Zyxel 600 series modem set up to phone line
You just have to perform a hard reset on the modem to erase any previous data stored. Locate the small pinhole for the reset button on the bottom of the modem box if it is not at the back. Then you need to access modem gateway to put all configuration information on modem software by typing in 192.168.0.1 in your IE browser's GO TO website box (where you type website address/URL)
NOTE: Make sure that you know your username and password for your current internet connection configuration before RESETTING modem. If you don't have this settings, call your internet provider. =)
Thanks.
Jan 02, 2009 | Zyxel PRESTIGE 645M-A1 (91-004-233005)...
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
