Question about Car Audio & Video
I have the code but it has a number 8 how am i supp. to input an ''8'' if there are only numbers 1-6 on the stereo???
    President:
  • 1,114 Answers
Usually, the numbers after 6 are entered by a combination of numbers at the same time or within a certain time frame. If you have the manual for the unit, it should be in there, if you don't, most mainstream manufacturers have a website and you can download the manual. Go to their site then look for a support link. If you can't find any info, post a comment with your units model number and I can dig further for you. Hope this helps
Posted on Jun 21, 2009
It seems to be stuck on low heat and will not go on to high no matter what we try
Instructions
1.Remove the faceplate around your stereo. Slip a flat object under the edge and gently pry it up. A flat-head screwdriver works well. There will be clips holding the faceplate in place, so feel for them. You may need to move your faceplate up or down to slide it out of position.
2.Find and remove any screws holding the stereo in place.
3.Slide the stereo component out far enough to see the label on top of the stereo. Write down the model and serial numbers of your car stereo component.
4.Locate your VIN number at the base of the front window, driver side. If you can't read your VIN off the window, you will have it on your proof of insurance and title as well. Write it down.
5.Locate your car manufacturer's toll-free Customer Service number and call them. Click on the link in the Resource section of this article and find your car manufacturer's toll-free number.
6.Call the number and let customer service know you need your stereo code and have the vehicle's VIN number, as well as the model and serial numbers off the stereo. They will provide you with the code. If you are unsure how to input the code, be sure to ask for support at this time.
Nov 26, 2014 | Cell Phones
Need the code for mobis hm 3700
I have a Kia Carnival 2005 KVII. I had to contact Kia to get the radio code and give the vin number. Note # you will only get 3 attempts.
My Kia has a Mobis HM3700 and the Code I was given is 1812.
To insert code:
1 look at the front of the Radio you will see a screen, and at the bottom of the Right hand side is a set of channel select buttons.
they look like this
1 2 3
4 5 6
Each button from button number 1 to number 4 will cycle through from 1, 2, 3, 4, 5, 6, 7, 8, 9, to 0 each time you press these buttons you will change the number on the screen.
When you have the numbers shown below
Button numbers 1 2 3 4
Numbers showing 1 8 1 2
Than press Number 5 button to accept
Jan 23, 2014 | Kia Cars & Trucks
Just bought 2002 Saturn L100 owner said radio worked before they took battery out to charge it. Now all the lights work but the sound wont come out. Help
Sounds like you need to input the radio code . i would look in the glove box for the code either on a sticker or a card or ask them if they know about the code .
Instructions
Deactivate Theft-Deterrent Feature
  • 1
    Place the key in the ignition and switch it to the "RUN" setting.
  • 2
    Press the volume control knob in to turn the stereo off, if it is not already off.
  • 3
    Press the number "5" and "6" button on the radio simultaneously for approximately five seconds until four dashes ("- - - -") appear on the display screen. You must then enter the four-digit unlock code that you originally assigned to your vehicle. If you are unsure of the unlock code, contact your local GM retailer.
  • 4
    Press "SEEK/SCAN" upward to set the first number.
  • 5
    Press "SEEK/SCAN" downward to set the second number.
  • 6
    Press "TUNE" upward to set the third number.
  • 7
    Press "TUNE" downward to set the fourth number.
  • 8
    Verify that the code on the display screen matches your stereo unlock code, then press the AM FM button. You will see "REP" will display on the screen. Enter your code a second time for confirmation. "OFF" will appear on the screen, confirming you successfully deactivated the theft-deterrent feature.
Nov 05, 2013 | Scosche Industries 08-up Saturn Astra...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
How to unlock the system of Pioneer X-MF3DVD-I?
Press Stop on the remote. Then go to the main menu and select option 4.
1. Press the ENTER button.
÷ The code number input screen is displayed.
2. Input the code number with the number buttons.
3. Select a level between level 1 to 8 with the direction buttons.
4. Press the ENTER button.
÷ Viewing restrictions are applied to the disc.
5. On discs where viewing restrictions have been set:
÷ The screen shown on the right is displayed when the PLAY button is pressed to start playback.
÷ Playback will start after the number buttons have been pressed to input the code number on
this screen, and the ENTER button has been pressed.
Oct 30, 2010 | Pioneer Audio Players & Recorders
Blaupunkt car stereo needs new code
try asking here
www.ukbookshelf.co.uk
as they offer free advice and codes , especially for these Bosch radios fitted in Suzukis
May 07, 2010 | Blaupunkt Car Audio & Video
1993 MAZDA MX 6 STEREO PROBLEM
If you enter the wrong thing 3 times I think your radio is useless
  • Press SCAN and AUTO.M until bars are displayed.
  • While the bars are displayed, input the code number by pressing the channel preset buttons 1, 2, 3, and 4. Press 1 for the first digit, 2 for the second, 3 for the third, and 4 for the last. If you number is 2547, press 1 three times, 2 six times, 3 five times, and 4 eight times. If the dispay goes off while inputing, begin from step 1.
  • Press SCAN and AUTO.M approximately 2 seconds and 'code' is displayed. 'code' will flash for 5 seconds, then disappear to indicate that the system is operable. If 'Err' appears, begin from step 1.
  • !CAUTION: Three consecutive errors will activate the antitheft system, and the audio unit will be completely inoperable and 'Err' will flash. When this happens, the unit must be replaced by an Authouized Mazda Dealer at the owner's expense. Do not allow unauthorized persons to attempt to input a code number.
    Feb 11, 2009 | OEM Systems Car Audio & Video
    Sucurity code for 2001 honda crv stereo
    pull radio out number on top of it call dealer give them number they ask for and they wil give you the code ck your owners manuel also it should be in there
    Jan 07, 2009 | Vehicle Parts & Accessories
    Zenith dvd/vcr mod #6711R1N211C. Need to prog the volume button.
    In my manual, to control a sony TV.. the code is number 8 or number 9.
    You will hold down TV POWER, hit 8 then release TV POWER.
    If that doesn't work, try number 9. Once the batteries are removed, it resets the code, so write it down. It will also over ride your old codes once you input the new one.
    Note: Depending on your TV, some or all buttons may not function on the TV, even after entering the correct manufacturer code.
    I looked for the section on Stereo, but all I found was the above.
    Hope this helps.
    Nov 22, 2008 | Zenith XBR411 DVD Recorder/VCR
    Car Audio & Video Logo
    21 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
