Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
High pitched noise
My fisher paykel makes a high pitched sound when it is taking the fill up water and mixing it with the detergent and that water isn't coming out right away.
  • smn4 Dec 05, 2007
    My six year old Fisher and Paykel is also making loud noises when filling with water.  And just today began leaking from the bottom a small amount of water.
  • 146 Answers
The inlet valve is faulty and needs to be replaced.
Posted on Nov 03, 2007
What does the FAULT CODE [off on off off off off on off] for FISHER & PAYKEL MW512NZ means
These blinks are fault indications. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 08, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Laundry detergent not dissolving
If you can let hot water to mix more with the cold when the washer fills, that will help the detergent to dissolve. If that's not an option, you can heat up about two quarts of water on the stove and when very hot, turn down the heat and add your detergent, then stir it till dissolved, and then add it to the washwater and clothes.
Sep 19, 2012 | Fisher and Paykel Washing Machines
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
Feb 19, 2011 | Fisher and Paykel Dishwashers
High pitched noise
This is a water pump about to blow, or a clogged filter or hose. The fact that you hear it immediately, and limited water level is involved, it's pretty much your bingo.
After turning off the water supply, unscrew the garden hose-like attachments for hot and cold water intake. There is sometimes a small filter right there where the water enters. If they're clogged, clean em.
Take the hoses and run them through an outside plug to make sure they aren't clogged with back flowed dirt from the filter and hard water.
If it still won't fill, you'll need to test the pump.
each machine is different, but if you follow the hoses from where your hoses enter the machine, you should be able to unscrew them at the other end.
Stick them in a deep bucket then turn on the machine and see what the pump does. Is the noise coming from it? (service or replace). Does water gush out of the pump into the bucket? (clean all hoses and filters, buy some machine grease and lube all the moving parts, including opening the water pump and giving it a generous amount of grease.
Put it all back and your squeal will one way or another be gone and you'll have plenty of water
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our machine functions correctly, but makes a high pitched -
need a new fill valve that what it sounds like check to see if your water is turned all the way on that can do it to.. and yes you can get parts for it
Jan 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
When washer is filling it makes a load screeching noise
Hi, welcome...
Your water pump is going bad most likely. This is easy to diagnose and also easy to repair. Under the control panel on top is a "tech sheet" that explains how to put the washer in "test mode". Set the machine in test mode and run the water pump independently and you will probably hear this same "schreeching" sound. The water pump runs at the begining of the wash cycle to recirculate the water and mix the detergent with the incoming fresh water. You also can "check" this by using the "PERMA PRESS" cycle. The perma-press does not use the recirculation feature, so the schreeching noise will be delayed to the first rinse cycle if the pump is bad.
The part number is 420325P and you can get them from
Feb 01, 2009 | Fisher and Paykel IWL12 Top Load Washer
When filling with the side fill pump makes loud screeching noise
Hi Tom. if the noise is a loud SCREECH that almost sounds like a wounded bird, you need to replace the water pump. The part is easy to replace with no tools and you can get one from Fisher Paykel Parts:
Dec 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Its taking longer than expected to fill with water.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Noisy Water Fill
try closing your water valve a little, see of that reduces noise level and even off. you wanna see if its your plumbing or the machines valve
Feb 24, 2008 | Fisher and Paykel GWL11 Top Load Washer
Soap cake not dispensing
it is highly recomended that you use powder detergent only absolutley no blocks or tabs or gels
Oct 17, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing Machines Logo
572 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
