Question about Motorola Mobility H700 Wireless Headset
I have same problem on my my first and second H700 headset. First one faled in 9 months, next one also failed within a year. Not at all satisfied with the Motorola product quality
Caller unable to hear me while using the H700 headset.
Hi there , to solve this proble since you have the headset over 18 months you need to change the internal battary the life time for these handset battery up to 24 months try to replace it by take it to cellphone shop and im sure you be happy.
Nov 30, 2009 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
H700 is paired...I can hear the caller but they can not hear me? Any help would be appreciated.
I actually had this same problem within the 1st year I had my H700 headset. I had to carefully pry open the flip end and remove a small piece of fabric that had been put inside by the manufacturer. After I had done this, everyone I talked to when I used the headset could hear me just fine. I am not really sure why it worked since all I did was take out a tiny piece of black fabric but it seemed to. I was able to also close the flip end back up as if I had never opened it and it still stays closed. I have still been able to use the headset even after about 5-6 months later but I did get an extra headset to have around if I need it.
Sep 29, 2009 | Motorola Mobility H700 Wireless Headset
H700 BLUETOOTH CHIRPS EVERY 9 SECONDS
my wife had her phone turned off internally.turned it on and problem solved
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Jun 20, 2008 | Motorola Mobility H700 Wireless Headset
H700 / Samsung Blade: WILL pair. Won't Connect!
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
The
Jun 15, 2008 | Motorola Mobility H700 Wireless Headset
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
550 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
