Question about Proscan 32LB30QD 32 in. LCD TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
    Genius:
  • 1,139 Answers
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 21, 2009
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
No sound when playing a dvd on a proscan lcd tv model 32LB30Q tv
Do you have a different audio source to test with (such as a tape player or vcr?) . That way you can verify if the DVD player is putting out audio versus whether the TV audio input is bad, or if the TV is configured to use HDMI for audio input.
Some TVs give you a setup menu option where the audio comes in through the HDMI port versus the (RCA) component ports. If yours is like that, then you should be able to switch that in the TV menu.
Oct 04, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LB30Q - Troubleshooting
Costco has one of the most liberal return policies around. Simply take it back and get your money back telling them "it doesn't work" as long as you have had it less than a year. Then buy a different brand. You might try calling for customer support from the different brand before you buy.
JG in AZ
Apr 11, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
PROSCAN 26" LCD TV with DVD won't show all the channels
bought 26 in pro scan tv can't figure out how to connect dvd player,craziest thing i've ever seen.please help
Mar 14, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan ps27108
are you changing the input to see it picture? have you connected the red input plug to the side of the tv?
Sep 09, 2007 | Proscan 19LA25Q 19 in. LCD Television
Proscan 32LB30QD 32 in. LCD TV Logo
620 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
