Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Lawn boy 2 cycle that smokes
28 years old. gas ration of 32-1 being used. Smokes really bad from under the deck. Sometimes power is there other times it isn't. It always starts up OK
  • panilling9
    panilling9 May 11, 2010
    since the exhaust is underneath be sure the bottom of the deck is clean of grass especially around the muffler area
  • 1,041 Answers
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
22hp.zero turn sometimes smokes then stops.
The smoke could be caused by blowby around the piston rings. Pour a small amount of transmission fluid in the spark plug hole and turn the engine over several times. Check the plug for fouling. Also check the coil wire for spark.
Apr 15, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I have a 435 husquvarna chain saw it is hard to start plus it idles high and it smokes and the chain keeps spinning when i let off the trigger
if it is hard to start and smokes sounds like the fuel is to old and the oil to gas mixture is wrong start off with some fresh fuel gas is only good for 30days in small engines
Aug 22, 2012 | Husqvarna 450 e-series 18" Chain Saw
How do i turn my power locked off?
First start with the set itself and look for any control switches that might control the power. Also check the back of the set for a master switch. If it isn't there take your remote and get into the menu function it shouldn't be hard to find. Look for anything that says something about power, it should say "power management" but it could all be under the sleep or stand by function. I cannot understand what the need for such a function is, for years the old "OFF" switch has done a fantastic job of power management. I guess it's no old fashion now, the living room light will be the next thing to go. I wish I was familiar enough with the set to tell you exactly which button to push but I would have to do a lot of research and I don't charge for my services, I just go on past experience. I've always had to search the remote to find what I needed and sometimes the over kill of gadgets is hard to hack through. One quick solution is if you have a kid from 5 - 15 years old around give them the remote they will be in it in a couple seconds. dhgill1949
Sep 01, 2011 | Hannspree XV32 32 in. LCD Television
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
Jul 27, 2009 | Honda Karcher G4000RH Pressure Washer
Mower starts then it smokes
If you spilled any oil on the engine, it will smoke for a few good minutes until it burns off.
Or, you may want to check the air breather. It may be dirty.
Jim
Jun 25, 2009 | Toro Lawn Mower With Toro Power Tools
Age problem
X+X+28=4(X+X)
2X+28=4X+4X
28=8X-2X
28=6X
X=4
The twins are 4 yrs. old. The mother is 32.
Do I pass?
Apr 21, 2009 | Mathsoft StudyWorks! Mathematics Deluxe...
My car just isn't what it use to be
Sounds like a bad head gasket
May 26, 2008 | 1999 Ford Escort
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
1,211 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
