Question about GE JKP27 Electric Double Oven
Top oven will not heat all the controls are active, bottom oven works fine.
  • 867 Answers
Make sure your program/timer cooking is off, other than that the element has probably burnt out
Posted on Jun 21, 2009
    Sergeant:
  • 212 Answers
Check voltage to element. should be 240v. if voltage is good then replace element.
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Oct 05, 2008 | GE JKP45 Electric Double Oven
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Ovens Logo
198 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
