How to get to battery
SOURCE: 2007 street glide misses and wonts to stall out when taking off??
my roadking just did the same thing, check the gasket between carb and intake
SOURCE: My battery was weak. I charged it and now It
If you used anything other than a 2amp trickle type charger you may have fried, yes as in completely roasted, Southern deep fat fried, Pok skins, fried a number of components from various relays to your ECM.
Check power on battery under no load. Look for something in the 11.5 volt plus ranges. With voltmeter on hit starter button and see if it drops.
Check power through to relays and beyond, this is a step by step process, there are no short cuts. It takes time and it is a pain in the backside.
SOURCE: how much air should I put in air shocks 2010
Don't mean to sound nasty but I thought new hogs have on board compressor to keep shocks,front and rear filled up?Your shocks need air maybe compressor aint working?Just a guess,sorry.
SOURCE: my 2010 street glide headlight
Check your tail light. If it's out as well, check the fuse panel for a blown fuse in the "lights" position.
Good Luck
Steve
SOURCE: have a 2010 street glide with harmon kardon sterio
do you mind me asking why you want a head phones on your bike? well anyways this is what you need to do, go down to radio shack and get a hook up and if your able to find a switch to turn off the main speakers so just your head phones are on. remove the head unit and locate your speaker wires now solder in the jac. best of luck if you need more help please contact me
M.Woodring
