Question about Dryers
Whirpool dryer takes 3 cycles to dry clothes
I have a large capacity dryer and large capacity washer. The dryer takes about 2.5 hours to dry a load of clothes.
    President:
  • 1,136 Answers
Hi, The first thing to check is the venting to the outside. Make sure it is free of lint and that it is not pinched at all.
If this is a gas dryer, there could be a problem with the coils on top of the gas valve.
Please let me know if I can assist you further.
Vic
Posted on Jun 21, 2009
Drying problem -
sounds like you have a washing machine problem , maybemore than a dryer . clothes should not be ringing wet from a washer ever.
Jan 20, 2015 | Malber WD1000 Front Load Washer/Dryer
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
My whirpool dryer (Duet) seems to always take (2) cycles to dry...After the first cycle the clothes are still very damp.
Your dryer may be pushed too far back , causing the vent hose to kink , behind the dryer . Also , check the outside vent airflow , and check the lint screen holder , for any peeled off lint , which could also be blocking the outside air flow .
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
Marvin
Marvin
