Question about Cell Phones
Charge I just found an ifone today on the ground. The battery is dead. What do I need to charge it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
If iphone's battery is dead u need to replace it no other go.u cant charge it .
Posted on Jun 21, 2009
No power to car
check to make sure the battery cables are tight and you have a good connection. make sure the ground wire is tightly secure to a solid metal ground.
Can it be jumped off?
If so, have the alternator checked at your local part store.
Apr 06, 2014 | 2003 Pontiac Sunfire
My CDI burnt out, the Rev counter went mad, CDI smoked, nd bike stopped with blown front & rear bulbs and a dead flat battery. I replaced all the above. a month later it's happened again, smoking CDI,...
Your regulator may have went bad. The regulator converts the ac charge produced from the alternator into the DC volts required to charge the battery. When they fail they can put out 5 times what the battery needs. Depending on your bike the regulator may be separate from the alternator. You should pick up a cheap volt meter. Once you get the bike running, use the volt meter to see what the bike is charging at. If you find the charge is above 14.8 V or that the voltage fluctuates to the extreme, ex. 14.2v, 8.2v, 12.7v all within a few seconds. then the regulator is probable. Another problem I have found is that the ground wire for wiring harness does not get hooked back up. This is a smaller ground wire that may plug into the main ground cable or sometimes is a separate lead connected to the battery. This will fry an entire system.
Oct 30, 2013 | Honda Motorcycles
Battery drained
what else is switched on.could be a bush that is clamping the starter drive gear.also could be a damaged wire to the starter
Jul 10, 2012 | 2000 Chevrolet Lumina
Battery is 100% charged but when i unplug the cable the computer goes off. Why?
The batterycould be old.
lithium batteries does not go dead when old
You simply cannot get the energy it stores.
That isthe draw back with them.
Other wise they would probably last forever.
Jan 20, 2010 | HP Compaq 6510b PC Notebook
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
Battery dead. Jumped off and it started but won't
TRY THESE TWO THINGS
1) WITH THE JEEP RUNNING AND A VOLT METER TOUCK THE BATTERY TERMINALS YOU SHOULD GET 13.5 TO 14.5 VOLTS
IF SO THE ALTERNATOR IS FINE
CHECK AND SEE IF ANY OF THE WIRES ARE IN BAD SHAPE FROM THE BATTERY TO THE STARTER IF OK THE NEXT ITEM WOULD BE THE STARTER COULD BE GROUNDING OUT
Aug 26, 2009 | JEEP Wrangler Unlimited Toy Vehicle
Dead battery won't recharge
If the battery is old, it just may be bad altogether. If so, it won't accept a charge. How are you charging it? (should be done with a battery charger NOT by driving) Make sure cable connections are clean (not just on the outside, but where they contact battery) OOPS... just noticed date on your post... likely fixed already... if not do what I said.
If it goes dead again, check alternator!
Jan 12, 2009 | 1995 Chevrolet Corvette
Cell Phones Logo
65 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
