Oreck steam-it Stick Vacuum Logo
A
Anonymous Posted on Apr 27, 2014
Oreck steam stick won't steam - Oreck steam-it Stick Vacuum
ORECK Steam 50 leaking
Hi, I would go to the following link since the manufacturer should repair or replace for free.
Clean Made Easy
Oreck steam cleaner, it doesn't give out steam
Use the tool that came with it to clean the nozzle where steam comes out. End nozzle also comes off so you can clean the larger hole with the other scrublike side of the tool.
Also, listen for steam assembly working, a low rumble like sound. If you do not hear it, it is broken and needs to be replaced.
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Oreck steam-it stick won't power on. It worked for a couple days then just quit. I bought it brand new. is there a DIY fix?
if you bout it a few daya ago dont try to fix it you self cause it kills the worentte take it back to where u got it or call who you odered it from the will replace it dont let them bull u ok you can return it with out a reciet they have it on record when you bout it best wishes ps jesus loves you he is comeing soon
The power turns on but the steamer will not turn on at all, it doesn't even light up the green button.
if its new take it back to store to be replaced or contack tell them what it is doing the will tell u ok god bless u jesus loves you j316 kjb please read it
Steam-it floor head brushes
my guess is probley used for low carpets or kinda like a dirt pusher just for a add on just for looks
I need a manual for the oreck floor steamer
Hi! Since you didn't mention the model type of your floor steamer, i'm giving you the link where you can see the user's guide for all oreck floor steamers. So, access this link (http://www.oreck.com/Owners-Guides) and go to the floor machines category (under electric brooms).
I hope this will work for you! Have a nice day!
I have the Oreck Sanapathic DMS2000 Handheld Steam Vacuum, but no steam comes out when I push the button. I hear the motor, is there any buttons I am missing or any help on how to make it work, been...
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Top Oreck Vacuums Experts
john h
hsapiens
Level 1 Expert
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
