No turn on
Hi... my air conditioner no turn on is dead .. the model is m6q08f2a and thank for help me.
  • pitotv Jun 21, 2009
    thank for answer me ...but i check it and problem is the a/c the question is...i can find the shematic diagram to the circuit board?
    Sergeant:
  • 340 Answers
Check the breaker. make sure their is power at the out let with a hair drier.if it works their is a problem with the a/c.
Posted on Jun 21, 2009
My Panasonic air conditioner model is A75C3012 when i turn it on it start 2or 3 minutes after that the timer light is blinking it turn off by itself. how can I fix this? Thank in advance
Try this and see if it works:
- check the remote and set the timer ioff;
- while is turned on, unplug the unit for 5 mins.
Hope it helps.
Regards,
Dan
Oct 19, 2016 | Panasonic Heating & Cooling
FixiaI need the code for the remote control SAMSUNG AIR CONDITIONER MODEL SH12ZB9.
hi if you input all the details on the internet the name and the model number it will bring up any relevent sites or type in code number for the remote for your unit and it normally brings a list of codes for different air conditioning units it should be there. Good luck .
Aug 04, 2014 | Samsung Heating & Cooling
How too separate from cabinet?
Hi Friend, I am happy to help you!
I see that your question is listedunder Frigidaire air conditioner and that you are looking for information on how to separate your air conditioner from its cabinet. May I have your model number please? The serial tag, which lists your model number, is typically located behind the front grill by the air outlet or on the inside of the cabinet. Other possible locations of the tag on room air conditioners are on the front edge of the chassis base or behind the dial plate of the control panel. If you have a split air conditioner, try checking on either the front or outer appliance on the right side of the cabinet. Hopethis helps and I look forward to your response. Thank you! - Z
Jul 24, 2014 | Frigidaire FAS257S2A WallWindow Air...
Hi, I have a DeLonghi pinguino PAC CT110. The circuit board is broken. I turned the on button on with the casing off, right on the circuit board. There is no power. Everything looks fine. What can be the...
Hi!
If your unit is totaly dead after plug power & turn on, no one of Led-s is iluminated or no "bip" sound generatet you have with alimentation cirquit, maybe the primary of transformator is burn. The pcb work with 12 V so you can conect a new transformator.
if the leds go on and you need to see if some error mesage is .
May 22, 2014 | DeLonghi Pinguino PACL90 Portable Air...
No cooling from unit
This could be anything from a loose low voltage connection to a dead unit.Please give more details if possible
Jul 26, 2009 | Ruud UBHC Air Conditioner
Dometic Blizzard 1300 roof top unit blowing fuses
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Sep 09, 2008 | Dometic Rooftop RV Air Conditioner
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
