Question about Xantech IR Programmer (RC68) Remote Control
We have set of DVD Sony DVP S560D,and Home Theater Sony STR DG520,as well SONY TV Bravia KDL 40S 4100,which we are controlling through universal Xantech URC 2 Remote,and IR Reciver with splitter and IR Emitters for 2 components ,and TV is controlled through RS 232 Black Box(Interactive TV), We have problem when one component is replace,it is not any more possible to control those as before. Is there any possibility to program Remote Manually without Dragon Software ..
Why nosound on sony 40cx520thru home theater
Check your TV Menu Sound output settings, Check your interconnecting audio cable and check that you have inserted the cable in the correct out/inputs on both items.
Jul 31, 2014 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
Apr 08, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Home electronics connections
See if this helps you. There are connection diagrams
https://docs.sony.com/release/KDL40Z4100_qs.pdf
Feb 22, 2014 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
Jun 02, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
DVP-S560D will not play some dvds, C:13:00 flashes at bottom of screen
could be a region issue, are the DVDs from a different region?
Oct 12, 2007 | Sony DVP-S560D
Televison & Video Logo
81 people viewed this question
Top Xantech Televison & Video Experts
Are you a Xantech Televison and Video Expert? Answer questions, earn points and help others
