My system doesn't detect the PNY Geforce 9400 GT (512MB) display adapter that I installed, although it is currently running the monitor. It is a PCI-E device. It doesn't show up in Hardware Manager. Also, my onboard sound is not working. I need resolution of these two hardware issues.
  • southswell Jun 21, 2009
    thanks, worked
    Scholar:
  • 119 Answers
I'll start with the Sound Issue, make sure the resources your sound device is using arent conflicting with any other hardware or application the system, if they are, you'll be able to see a yellow exclamation mark next to the icon. If there isnt any sign ntu still the device is not working, uninstall the devices drivers and download and install updated versions of you audio codecs.
As for your display, if you had an old one and you simply unplugged it and placed your new one in the same slot, that could be causing the detection issue, computers really arent that smart. so you'll have to make sure any previous versions of display drivers that could be preventing the new adapter to be seen must be carefully removed.
Posted on Jun 21, 2009
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
My gpu card is not being detected at all.its a pny gts 450
Hi there.
I suggest you make sure that you are running the latest diplay drivers for your GTS 450.
You can get them at the Nvidia download center here.
Just select the following from the drop-down boxes.
Product Type: GeForce
Product Series: GeForce 400 Series
Product: GeForce GTS 450
Operating System: Your current operating system.
Language: The language that you want the setup to be in.
Then click the search button.
Click download on the next page. Once downloaded, run the setup and it will install the driver. You will need to restart to finish the process.
Slasher_X
Jul 07, 2011 | PNY Technologies Pny Geforce Gts 450 PciE...
Describe your PNY GeForce GT 240 win 7 64 bit Driver problem
Refer the first link if you are unable to install drivers or if you lost the drivers cd for pny GeForce GT 240 and if you want to know more about pny GeForce GT 240 than refer the second link
http://www.driversbay.com/drivers/graphic-adapters/pny/gt-240-512/
http://www.legitreviews.com/article/1192/1/
All the Best...
Feb 18, 2011 | PNY GeForce GT 240, (512 MB) PCI Express...
Geforce 8500 won't show on computer and fan is working but no show how to fix
you may have to dis able the Onboard  graphics system and may need to check some things
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Oct 02, 2009 | PNY Verto GeForce 8500 GT 512MB DDR2 PCI...
A display problem of monitor comes with geforce 9400 gt pci ex. card. how can i solv it? when i insert cart the display of monitor out. how can i solv it?
According to the specs of the MSI 9400gt 512mb HDMI graphics cards, its system requirements are:
1. PCI Express or PCI Express 2.0 - compliant motherboard with one x16 graphics slot.
2. Power supply of 300 (and up) watt is highly recommended for system stability.
Make sure that your power supply meets the or exceeds the system requirements for this graphics card.
Jun 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Error code 43 "Incompatible display adapter has been disabled"
I have got Dell comp with same n-vidia 8800GT suddenly after installing adobe's update only 1 monitor functions and slowly.
Any reinstaling and updating drivers that i ve tried did not help.
May 07, 2009 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Card not recognized
Hi jtreed,
You may have a DOA graphics card ( dead on arrival ) contact the shop you got your card from and request a RMA.
Oct 17, 2008 | PNY Verto GeForce 8500 GT 512MB DDR2 PCI...
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
