Question about Garden
I have a 46 inch husky and it started sliping when you drive it so i put 2 new drive belt on it and it still slips i check the rearend and it is fine and the motor runs like a top what is the problem did you know
  • panilling9
    panilling9 May 11, 2010
    just a question
    did you have the rear wheels off?
    if you did or didnt be sure your key stock is present at the rear wheels(both)
  • 513 Answers
There are metal keys that hold the tire and axle intacked to move together look at wheels & axle & key your problem is possably there
Posted on Jun 28, 2009
1997 mtd riding mower 46 inch deck runs good does not seemed to go as fast as it did last year slower moving does it have fluid in rear end and if it does were do you check
a lot of the time on older models the drive belts tend to wear out and slip some. hills and pulling a cart make them wear out faster. you said you have a 1997. if the belts have never been changed i would bet that it just needs new belts. you may check to see if there is any oil or grease on the belts if not put some new belts on it and it should be good. i hope this gives you an idea on where to strt.
May 05, 2016 | Mtd Garden
Is there an additive to add to hydrostatic trans to stop slipping?
Once there is wear internally no addative is going to help, you could try a thicker gear oil but this will only be a temporary fix, hydro units can be repaired, most makes will have parts available.
Aug 09, 2012 | Garden
Drive belt slips on Husqvarna YTH21K46 riding lawnmower, installed new drive belt and it slips. mower is 2 years old
I had this same issue. New belts and correct routing did not solve the problem. The issue with my mower was the tabs that come off the frame that you bolt the transaxle (the drive for the rear wheels and axle) had almost completely torn/cracked away. This allowed the transaxle to tilt forward under a load and slip the belt off the rear drive pulley. You see no mention of this at the dealer or company sights. The tabs are so thin this is going to happen, in my opinion, in time. I reinforced this area with 1/4 inch angle iron and have had no further belt issue.
Apr 21, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Crank pulley/harmonic ballencer is almost a half inch off from all other pulley on my 99 3.1 malibe
You need to replace the harmonic balancer it is coming apart.the outer part of crank pulley is actually rubber mounted to the inner part.
Mar 18, 2012 | 1999 Chevrolet Malibu
Mower belt keeps sliping off pulley near discharge chute. I can mow for about 10 to 15 minutes then it slips. Belt is not new ( 2 years old) but is in fair condition.
Hello, David, W/D here.
It may be time for a new belt. I have a new Husqvarna and it needed a new belt after one year. Curiously, the replacement belt has lasted much longer that the original.
Best regards, --W/D--
May 17, 2011 | Garden
Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Sep 19, 2009 | Garden
Rearend sliping
Have you checked your drive belt(s) for wear or pieces missing. With engine off and clutch/brake pedal up, check the tightness of the belt. You may just need a new belt.
May 23, 2009 | Mtd Garden
My garden tractor makes a funny noise when i put it in drive
Wrong belt size? Did you put everything back the way you took it off to put the belt on? Usually, it's the belt, if it doesnt fit tight it will vibrate, have a burning smell and wont let you shift smoothly.
Dec 29, 2008 | Garden
Hi,Ihave a hoover hnf 7167 washing machine that my 2 year old turned off then on again while on a 1600 spin(the washing machine,not the 2 year old!!).This caused a loud'pop'and everything went blank.The 13...
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Sep 12, 2008 | Hoover Washing Machines
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
