Question about Olympus Photography
I need a REPAIR manual for Olympus Stylus Epic Zoom 80 film camera. I need to replace the lens barrier.
I need a manual for a Olympus Stylus Epic Zoom 80 (film type) camera.Thank you
http://butkus.org/chinon/olympus/olympus_stylus_epic_zoom_80/olympus_stylus_epic_zoom_80.htm
Aug 17, 2010 | Cameras
Camera is jammed.
this is a lens problem you must find and replace the lens block for you camera.. search on ebay ionternational seller. it s possible that you can find the lens block for you camera,, the cost of the entire lens is 25 ----35... euro...sorry for my bad english i repair cameras but i am italian
Jul 25, 2010 | Olympus Stylus Epic 115 QD 35mm Point and...
Lens won't retract and it makes a racheting noise when battery is inserted. Can it be repaired?
Most probably and or dirt has gotten into the lens mechanism, could also be a damaged or worn drive gear. Can you see score or scratches on the lens barrel? If the camera is still working then I would keep on using it. A repair would not be economical so a replacement is the only option.
Jun 30, 2009 | Olympus Stylus Zoom 140 35mm Point and...
Reads "Error"
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Mar 27, 2009 | Olympus Stylus Epic Zoom 80 QD 35mm Point...
Camera won't work, has an E on the display
If E blinks in the exposure counter, the film is improperly loaded. Reload the film.
Her is the link to the Olympus website where you can download the instruction manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=298
Feb 13, 2009 | Olympus Stylus Zoom 80 Wide DLX 35mm Point...
Problem
You haven't specified what camera model you have, but I suspect the problem could be due to the white balance setting on the camera. Read your owners manual and check the section on adjusting the white balance. If you have it set for something opposite to the actual ambient lighting condition (ie the setting is for incandescent light bulbs, and you are shooting outdoors in sunlight, for example), then it can really throw the colour spectrum off.
Nov 23, 2008 | Olympus Stylus Epic Zoom 170 35mm Point...
How to set date and time on a olympus stylus epic zoom 170
Hi - You can download the manual by clicking the link underlined in blue below:
epic zoom 170
See page 52
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 16, 2008 | Olympus Cameras
C-2100UZ and low light
If you don't need a zoom, the best film P & S that you can get for what you described is an Olympus! It is the Olympus Stylus Epic which has a very sharp 35 mm f2.8 lens. The f2.8 lens with an ISO 800 or the new ISO 1600 film should fit your bill for low light, fast shutter speed photography. B & H has it for $80. Popular Photography magazine once called it the biggest bargain of all times for no-flash photography.
Sep 11, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Photography Logo
327 people viewed this question
Top Olympus Photography Experts
pontelemon
pontelemon
Steve
David Payne
David Payne
Are you an Olympus Photography Expert? Answer questions, earn points and help others
