Question about RaidMax Computers & Internet
Does anyone know why the Raidmax 75 n 1 card reader dont work when plugged into the usb port
Every port I tried gave me the same effect. It just has a red light that comes on in the front of the unit. Are they wired different from other usb devices?
SOURCE:
  • 130 Answers
SOURCE: problems with auto download from a card
I dont think it will automaticly download with a card reader. Windows XP will detect that a new USB device is installed and it will open a menu to look at the files or play them but i dont think it will automaticly download. The card reader acts as a removable storage device so you need to tell it what to do. The only way it will download images is threw the camera. You will have to drag and drop them from the card reader to a folder on your computer. Go to mycomputer then next to your "local disk C" there will be a new icon that says "removable storage device" open that then inside there you may have another folder with theimages on it. Click edit, select all, then copy. Paste them into a folder on your desktop or in my pictures. The card readers are a general use device meaning it does not know if you are using it for a camera, mp3 player, a phone so it needs to be told what to do. Hope this helps!
Posted on Mar 30, 2006
SOURCE: Red Light instead of a Blue one
I've seen this before. The power LED needs to be replaced. If you have the sales receipt, Raidmax will replace it. This won't affect any other part of your PC, so if you don't get it replaced, it's not the end of the world. =)
Posted on Jun 12, 2007
SOURCE: front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Posted on Aug 09, 2008
SOURCE: Installing a card reader
On my E210882 motherboard in an Emachine T2824, the card reader is plugged into J9F2 connector on the motherboard.
Posted on Sep 23, 2008
kiran_G4E
  • 59 Answers
SOURCE: Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Posted on Jan 01, 2009
I cammot see my pictures in the camera i dont know what to do ?
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 27, 2012 | Samsung Digimax S700 Digital Camera
Everytime i try to download music to my memory
try using a different USB port to put the Dynes reader into then insert the memory card in it once the dynes reader is detected by the machine, if still not being detected check the services window
in XP click start open the run window type services.msc in the list look foe Human Interface Device Access double click and change it to Automatic, then look for Plug and Play do the same set it to automatic, then look for Universal Plug and Play Device Host set it to automatic as well make sure that after you set each that you click apply then ok to make changes take effect, after you've done the automatic settings remove the dyne card reader restart the computer aftrer restarting then insert your mini memory card into the dyne reader then insert the dyne reader into a USB port on your computer, Hopefully this should work ^_^
Jun 04, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Gateway GT5228 - USB Ports & All-In-One Card Reader don't work...
what service pack froom MS have you downloaded and installed? Sounds like the SM BUS DRIVER ARE MISSING. Install SP3 AND LET ME KNOW.
Feb 16, 2010 | Gateway GT5228 PC Desktop
I lost the computer chord so i am trying to put the memory card into my computer to upload the pictures and nothing is showing up, what do i do?
You may need to install the USB card reader software on the PC. Frankly if you are having difficulty with this it might be better to shell out a few pound/dollars on a card reader and plug that (with the card plugged in) into a spare USB port on the PC.
Jan 03, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Nov 19, 2009 | Electronics - Others
My remote don,t work on my acer 1800 , and the sd card reader don,t read. I did replace the battery in the remote,I have XP MEDIA CENTRE installed on the laptop.
laptops don't have remotes, and for the sd card reader unplug it from the laptop and try it in a different usb port if that does not work then i dont know. ive got an sd card reader and my laptop didn't find mine until i tried it in a different usb port
Oct 27, 2009 | Acer Aspire 1800 Notebook
I'm trying to use the Sakar CR-75 Digital Card Reader to transfer photos from my telephone memory card to my computer. I've done this in the past with the same card and the same computer but now I can't...
does the same happen if you try on another computer (if it does then replace the cable or connect device directly without usb cable extension (if applicable))
if it works fine on another computer..
what happen after you plugged the device on your computer? have you try different usb ports? does other devices work fine on the same usb ports on your computer?
Dec 02, 2008 | Computers & Internet
Media Card Readers
yess use the ports in the back of the computer I had the same problem with my mouse before which was also usb port connection. The reason why I say to hook it up to the back usb ports is that it is built onto the motherboard and therefore it would get recognized alot quicker if you put it there if you find that whatever you have hooked up dont have alot of usb ports buy yourself a usb hub i bought one for 2.00 it does the trick when you are limited to usb connections
Sep 26, 2007 | Intel SYNTAX S651M SIS651 mATX (SYNTAX...
Problems with auto download from a card
Sep 14, 2005 | Canon PowerShot A95 Digital Camera
S75 & Mem Stick Reader Help
I had the same concern a month ago when I bought my USB Stick reader. As you mentioned, the manual says there is no guarantee... I don't have a USB hub but I do use the USB port that I connect the USB Stick reader for other things. No problem. In fact I did not even have to use the supplied CD that came with the reader to install the driver for it. As soon as I pluged the reader to the USB port. Windows ME (yes I'm running WindowsME) found the device and install the built-in driver itself. Why don't you just wait until you get your camera and try it out first. Good luck.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Computers & Internet Logo
60 people viewed this question
Top RaidMax Computers & Internet Experts
Alun Cox
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
