Question about Lands Phones
My phone is malfunctionning. The word "SEARCHING" is flashing on my handset. Nothing I do restores normal use. I have switched off the power, taken out the batteries, pressed many buttons. Can you help?
  • 48 Answers
If it's a cell phone, chances are it's your carrier that is at fault.
Posted on Jun 22, 2009
Phone will not connect to base stations. Handset says "Searching" and will not connect. I have tried to remove battery from handset and power plug from base multiple times, but nothing works.
check instructions for "pair" ...you may need to pair them before it sees the handset . there will be a button on the base and one on the handset ?
May 07, 2015 | Lands Phones
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Dec 22, 2008 | Philips DECT 2252S Cordless Phone
AT&T hanset indicates "Searching for base"
how long since the handset battery was replaced anything over 12 monts may be a battery problem
May 15, 2017 | AT&T 2455 Cordless Phone
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
Philips dect245 searching problem
1. try to reset handset. try sw reset in the manual .
2. try to clear the base. unplug power cord, press and hold "page " key , and plug the power cord , after 5 to 6 second release page key.
3. Register again.
4. If there is still searching , open the base and handset, to check ,if the antenna is broken or not.
Jul 30, 2008 | Philips DECT 2252S Cordless Phone
Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Sep 20, 2007 | Siemens Gigaset 4000 Phone
Handset flashes "searching" and has stopped working
Did you already try cleaning the connections on the phone and the base with alcohol on a Q-tip? Make sure the connections on the phone are touching the base propely.
Jul 19, 2007 | Siemens Gigaset 4210 Cordless Phone
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
Lands Phones Logo
18 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
