Question about Panasonic PT-44LCX65 Television
When i turn on my panasomic lcd tv it gives me a lamp error.
My picture is fine, i just want to know how to reset the lamp hour meter.
    President:
  • 1,077 Answers
Try this:
Using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Or try:
Use the pip button on the remote and the down volume button. press and hold about five seconds.
Posted on Jun 21, 2009
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Where is my lcd lamp located on my panasonic rear projector tv?
How to change lamp on PT52LCX15K
Turn TV off and wait for the red light to stop blinking,then unplug it from the wall. IMPORTANT: Wait for a least a hour after turning off your TVfor the lamp to cool off. It is veryhot On a Panasonic PT52LCX15K the lamp is located under thefront panel that covers the speakers.
  1. Remove the front panel. Just grab it on both side and pull gently.
  1. TO THE RIGHT OF THE LEFT SPEAKER you will see a round locking knob on the lamp cover. Turn the knob to the left and remove the cover.
  1. Inside you will see a case with a handle on it. Pull it out and you will see the lamp assembly
  1. Remove the two screws holding the lamp assemble and remove. Use the handle.
Putting it back in just do everything in reverse. You will have to reset the lamp meter yourself.To reset the lamp hour meter:
Hold down the volume button on the TV and at the same timepress and hold the PIP (picture in picture) button on the remote. Watch the screen and you will see when it is complete. It only takes a few seconds.
Sep 11, 2010 | Panasonic 2 Projector Lamp
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
SAMSUNG 52'' PCN5425R TV WONT POWER ON
when the timer light is turn ON, tv is telling you that lamp will be going out soon, is basically a hour meter, it just reach the limit of hours that tv haves program of use for a lamp and that you can reseted by:
1.- taking the lamp out nad in again, that way tv will detect there is a new lamp. If not.
2.- folow the instructions: http://www.fixyourdlp.com/blog/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter/
Jun 25, 2009 | Televison & Video
Need to reset lamp hours for KDF-E55A20
This model does not require lamp timer reset, put new lamp securely and power up TV for picture.
Jun 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turn on tv get error message Lamp needs to be replaced and the Lamp Hour meter needs to be reset. I still have picture how do I reset this error message
Howdy,
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Mar 25, 2009 | Panasonic PT-44LCX65 Television
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Spark Gap Lamp Driver Problem? Sony LCD TV?
Lamp driver error 5 times - Lamp driver is faulty. The symptom will be no picture or sound . Repalce the lamp driver.
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Panasonic PT-44LCX65 Television Logo
361 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
