Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cannot get local channels
I have the 52 rear projection HDTV RCA and there is no coax input for local channels. I have directTV and cannot get any local channels on my big screen. Thanks.
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Posted on Sep 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
video-tek
  • 150 Answers
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Posted on Jun 05, 2009
RCA HD52W59
I think already answered this but:
If on screen menu comes up hook up something to one of the rear av inputs and see if set works (have to move to that input with remote or input feature on front of set)
if picture etc that way tuner in set may be bad (look to see if coax fitting is loose or broken)
Mar 11, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where does my coax cable plug into this tv? I can't find the cable jack.
In between your composite inputs and audio inputs on the back, there should be a coax plug that says antenna/cable. Plug it in there and you should be good.
May 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
The coax connector broke off on my rca d52w20 how can i fix it
you can take it to a repair shop to fix or the easiest way is to use a different input. try using the rca cable connections (the red, white, and yellow) to run from the cable box to the tv
Oct 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't recieve digital channels
I have the same type of TV and as soon as i figure out why it also, will not convert from analog to digital ,I can hook up to converter box get all kind of clear channels I am quickly finding out These Sets Are either minor problems or very major problems. They have over 32 different SSB tuner boards,and they all look alike but are not, hookups and connectors are not the same.
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Mar 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
TV Changes Channels on its own
On the front panel board power/ch-/ch+ vol-/vol+ replace contact switches replace all of them.For some odd reasons these contact switches just keep going out they had alot of them bad.
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd61lpw42 rca tv
I also have an issue w/my RCA rear projection TV making a piercing sound. My TV does not do it on the HD channels, but does make the noise on the regular cable channels and on On-Demand as well.
I
Dec 27, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
