Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
Same problem... I'm having the exact same issue, but mine sparks every 18 seconds. Perhaps this is a faulty spark module?
  • 530 Answers
That' pretty much the only thing that would cause that issue.
Posted on Jun 21, 2009
What would cause my motorcycle to stall or shut down after shifting two first gear down from second after it down there isn't any Spark and the bike will not start it's a 2005 Yamaha V Star 650
Hi, George and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.starbikeforums.com/forums/18-engine-work/2886-no-spark.html
no start or no spark
How to diagnose no spark situation on motorcycle Yamaha XVS650 Service Manual
OEM parts for Yamaha
Yamaha star XVS650P Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 20, 2017 | Yamaha V Star Classic 650 Motorcycles
2008 triumph Daytona 675 has rough idle on startup for about 30 seconds
Hi, Marcel and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intermittent short circuit due to damaged wire insulation.
8. Intake air leak.
9. Water, dirt, or rust in the fuel system, fuel pump and/or filter.
10. Faulty fuel pressure regulator
11. Fuel tank vent system plugged.
12. Throttle body controls misadjusted.
13. Damaged throttle body or intake seals.
14. Loose, dirty, or corroded ignition module connector at crankcase.
15. Faulty MAP, CKP, O2, and/or CMP sensors.
16. Incorrect valve timing.
17. Weak or broken valve springs.
18. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Rough Running Engine James on Engines 2
fuel injected bike running real rough
How To Diagnosing Bad
Triumph DAYTONA 675 Service Manual
Jul 08, 2016 | 2008 Triumph Daytona 675
I lost spark on my 2004 v star 650 classic
Hi, Anonymous and the usual suspects are:
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
https://dd5394a0b8ca8e97ba29-abf76f3d91a2125517d6c7c409f095c7.ssl.cf1.rackcdn.com/content/common/manuals/1999/LIT-11626-12-30_126.pdf
Feb 21, 2014 | 2004 Yamaha V Star Classic
No spark
6. Faulty ignition coil or ignition / electronic module
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Feb 20, 2014 | 2004 Yamaha V Star Classic
Bike won't start
Nov 17, 2013 | 2002 Yamaha V Star Classic
2002 v star 650 no spark to rear cylinder has spark on front
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
05 Star 650 Custom second cylinder not getting spark
YAMAHA XVS650 Owner Manual
May 18, 2012 | Yamaha V Star Classic 650 Motorcycles
1996 Kawasaki ZZR 250 no spark
Hi, Limp_me_101 and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
https://netrider.net.au/threads/zzr250-no-spark.75542
97 Kawasaki Ninja 250 Project No Spark Electrical Testing
Kawasaki ZZ R250 Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Jun 02, 2011 | 1996 kawasaki ZZR 250
Motorcycle not firing at spark plugs
Hi, Kdenton752 and the usual suspects are:
Nov 21, 2010 | 2005 Yamaha V Star Classic
2005 v star 650 i have no spark in spark plugs
Hi, Rstdog1 and the usual suspects are:
Aug 16, 2010 | 2005 Yamaha V Star Classic
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
71 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
