Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
A
Anonymous Posted on Apr 27, 2014
Compaq presario C700 continous beep when starting up
When loading Windows on starting up. Computer keeps on beeping until Windows files have been loaded. Then goes into startup repair
Dave Marksmen
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 21, 2014
Dave Marksmen
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
8540
Points
35
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
4 Related Answers
Anonymous
  • Posted on Jun 05, 2009
SOURCE: continuous beep on compaq presario s3200nx
I had the same problem, but then cleaned my computer with pressurized air and it now works. Try that and see if it works.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on May 21, 2009
SOURCE: While xp pro is running 2 beeps then shuts down
Hi there.
2 beeps is usually a parity circuit failure and is in most case to do with the system memory.
Get a clean, dry, soft paintbrush, remove the power cord, take the side panel off the computer and remove the ram (memory), clean the brass pins on the memory and the slots that the memory sits in with the paintbrush, make sure you get rid of all the dust, blow on the slots when done and reseat the memory making sure it snaps into place and is nice and tight, return the side panel and the power cord and start the computer, hopefully it will stay on for longer.
Please post back with the results and thanks for using FixYa!!
Anonymous
  • 35 Answers
  • Posted on Jun 22, 2009
SOURCE: Compaq Presario SR2010NX beeping
sometimes using an eraser over the metallic part of the RAM stick can get it to be read to the system..i have tried it many times it works
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Sep 11, 2012
SOURCE: Compaq Presario C700 Drivers for Windows Server 2003 64-bit needed
http://device-driver.org/download-driver?tid=bcpresariof001compaqxx&src=b
not sure if its free
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
Compaq presario C700 beeping
Just singing you a song.
Your laptop, and you have bonded now. It feels comfortable with you; and is serenading you.
NO! You gonna' believe that? lol! Geez.
Beeps you hear are BIOS Beep Codes. The computers method of telling you something is wrong, and an area to look into for it.
I'm willing to bet the laptop is dirty inside.
This would be one major problem.
Secondly, you should clean the gold plated contact pins, of the Ram Memory modules ('Stick'); with a pencil eraser. Use air to remove the eraser dust, then reinstall.
Third, the Thermal Paste on the Processor is probably drying up, (or has dried up), and needs to be replaced.
All of the above has specific procedures. Plus an ESD wrist strap should be worn, and it's alligator clip attached to a good ground source.
Average cost is around $3 to $6.
I can guide you step by step, if you wish.
Post back in a Comment.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with -> Compaq Presario 1100.
(1100 in blue)
Scroll across, and click on the blue -> C700.
This is a Service Manual.
(Free, but donations are accepted, according to the owner)
Regards,
joecoolvette
1helpful
My compac presario PC SR5510F keeps beeping and wont start up? do you know why that would be
When a PC is turned on and then starts beeping, the beeps are actually a message to help troubleshoot. You should listen to the beeps and learn what the pattern is. With that pattern, you may be able to determine the issue.
HP has published a list of these beep codes that are common to many of their system. That information can be found at this link > HP/Compaq Beep Codes
Beeps continously at star up, changed to linux ubunto and same thing, Up dated Bios but the problem remain,, thanks for and advise.
Beeps signal a hardware fault. To find out which part is faulty (usually it's the memory) you must start to test the pc by replacing parts one at a time until the beep stops.
Presario c700 powers on, i hear it and has lites on power and wirelss but no dosplay
r u hearing continuous beeps sound. i.e. motherboard display is gone.
if u hearing 3 beeps. then ram is gone.
My laptop has starting prolem ...when i am switch it on ... it is starting with contineous sound of beep....and also my touch pad mouse is not working some time properly... i had format it two times with...
Hello, hetul58519
I installed some extra memory on my PC, didn't do it quit right and recieved a series of beeps untill I fixed what I had done incorrectly during the install. The beeping is the computer way of telling you something is not right, it is trying to audibally tell you what that is. Now, it is up to you to search for the hidden meaning behind the continuose beep. Do a search for "computer beeps" or "computer audio cues". Do you recieve any warnings other then the beep? Is the computer acting funny in any other way?
2answers
When I go to boot the pc, it just beeps very loudly. Never boots.
thats normally means your video card has a fault, especially if nothing comes up on your screen and you just hear beeps
My Compaq Presario notebook won't start up
Hi there
at boot, hit F8 and then select "last known good configuration"
/Teis
Compaq presario c700
is it a kind of beep ... or please discribe what sound .. how much times .. it repeats .. etc..
Beeping Blues
Something has hung up. Try removeing hardware, ie... battery, cd drive, keyboard, etc... until you find the nonessential piece of hardware that is hanging up your boot process. (nonessential to the operating system)
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
