Question about Honeywell Heating & Cooling
3 year old Lennox system stops intermittently 2-3times past 24hrs
3 year old Lennox system stops intermittently. We reset the thermostat and the system starts back up. We don't notice this until the temp has risen several degrees and it is getting uncomfortable in the house. 1st time found the thermostat was blank no backup batteries had ever been installed. installed batteries and cycled the circuitbreakers. This has happened 2 or 3 times in the last 24 hours. Any help is appreciated!
Honeywell thermostat
  • 148 Answers
I would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Posted on Jun 21, 2009
Does a y2081 lennox thermostat have a batteryin it
Yes it has 3 AAA batteries.
Pull it straight off the wall. Look at the back of the thermostat and replace the three batteries.
Link to manual..
http://www.lennox.com/pdfs/manuals/Lennox_Elite_Touchscreen_Manual.pdf
Sep 10, 2014 | Lennox Y2081 ComfortSense 7000 Thermostat...
Replace thermostat
What is the model number of the old tstat and furnace?
Aug 07, 2017 | Heating & Cooling
I have a lennox 2 stage gas furnace and a lennox XP15 heat pump controlled through the Lennox 7000 touchscreen thermostat. I want to disable the heat pump due to excessive noise due to lower temperature...
At tstat press options. Press installer setup. Yes, you are qualified. System settings, non heat pump. Gas/ oil heat. Save changes. That should do it with no wiring changes.
Jun 18, 2017 | Heating & Cooling
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
303 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
