Question about Fuji FinePix A600 Digital Camera
The shutter that protects the lens stays shut all the time
You can push the shutters back with your finger to take a photo but they won't retract on there own can they be removed or is it a simple job to repair
  • 12 Answers
Camera repair is expensive no matter how small the job... i would not recommend removing them as your lens would then be unprotected. My advice is to either put up with having to push them apart, or to buy a new camera (probably cheaper than doing a repair)
Posted on Jul 27, 2009
Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jun 06, 2010 | Canon PowerShot A510 Digital Camera
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
LENS IS JAMMED ON MY Canon A510 PowerShot
pls see these links they will help u
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
http://www.flickr.com/groups/a510/discuss/72157594369867126/
pls rate me well !
May 10, 2009 | Tokina 3652T for Canon Power-shot A510,...
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Canon Elph shutter won't retract and camera won't shut off.
Very common.
Broken Shutter Flex cable in the lens.
Needs replacement.
Apr 05, 2009 | Photography
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
Lens won't retract
Mine has done this twice, both times requiring it to be sent off for repair, both covered under warranty though luckily. Both came back saying they replaced the shutter assembly. Camera is fixing to go back out for a third time (not shutter related). I've lost all confidence in canon with this one.
Oct 25, 2008 | Canon PowerShot SD870 IS Digital Camera
Fuji FinePix A600 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
