Question about Hunter Ceiling Fan Remote Receiver 85112-01
Hunter Fan Remote Control Part No. 85095-01: Unable to reverse fan direction. All other controls work OK. Stuck on Upward air flow direction.
My Hunter Remote does not have a Reverse button and can't find the manual
Posted on Jun 11, 2010
Fan and Light Does not Work Part No. 85095
FCC ID IN2TX13 Freq 350 MHq
I had checked wiring and had an electrision look I believe it could be the remote Part no Above, Where can I buy a new remote?
Posted on Apr 06, 2011
I accidentally dropped my remote and when I went to turn off the fan...it stopped working. I love the fan...but when I manually turned it on at the switch - the light came on but not the fan. The battery is fine - and working...'cause the red light comes on when a remote button is depressed...but none of the fan buttons work. Any thoughts on how to fix this. OR - do you know where I can replace the remote. Thanks...
Posted on Aug 31, 2012
I had the same problem. I found that the reverse button needs to be pressed really hard. It now works but I need to press that button really really hard.
Posted on Jul 17, 2009
Take this **** down and replace. I have 3 of these fans and not one of them works . Who would build something that couldnt be operated without the remote?!! Thought i was up gradeing
Posted on Jun 02, 2012
  • Don B Jul 10, 2014
    Mine quit again...ANSWER #5 ABOVE!! I ACCIDENTALLY stumbled on this solution
    My Hunter remote is a 85095 - 01 Part #...oops...sorry! As the fan is on and turning, hit and hold the light power button at the bottom. Then hit the MEDIUM fan speed button that has 2 embossed dots on it. My fan reverses at this point...your should too!! One other tip i discovered...with the light on...hit and hold the light power button...the light dims 'till you let it go!! GREAT mood lighting!! Enjoy!! Let me know hot it goes!!
    New Friend:
Remote 99600
i hav? had this remote control Hunter fan for +- 3 years and just stopped working.....
changed battery in remote, checked breaker .....still nothing . Could it be the remote that would hav? to be changed ???
Posted on Jan 09, 2015
  • 110 Answers
Oddly enough, when I had this problem, all I did was to change the battery. Apparently, it must need just a bit more power to reverse. I hope this helps you like it did me!!
Posted on Jun 22, 2009
How to reverse fan?
to change the fan from counterclockwise to clockwise get the fan going on hi. Hold the hi button while switching the wall switch from OFF to ON quickly. The fan will switch direction. To go from clockwise counterclockwise just hold down the low speed button until the fan switches direction. This makes no sense but it works only took 7 years to figure out.
Aug 10, 2014 | Hunter 27185 Remote Control
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Reverse hunter mission fan
need to know how to programme carib 880e remote
Jul 23, 2013 | Hunter 54"" 1912 Mission 5 Blade Ceiling...
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hi I need to know if I can switch the direction my hunter green Lasko fan is turning it is going clockwise and I would like to reverse it for the summer can't find a switch we've have it for...
Turn the fan off. Locate the reversing switch. It is on the base of the fan near the fan speed and light switches. if its not on the remote control. have a good day !!
If it does not have a revesing fan switch and its older, You may have to physically(with fan stopped)
Push blade in from end and twist blade for reverse air.
Jun 22, 2011 | Hunter Traditional Southwest 52" Ceiling...
Just installed a hunter 27227 remote for use with my Hampton Bay fan. The fan was electronically reversable via a F/R switch on the old remote. Everything is working great except that the thing is running...
I recently had Hampton Bay fans installed with the Hunter remote and the electrician showed me that there is a small switch on the fan and you turn it either up or down depending on whether it's hotter months or cooler months because it changes the direction of the airflow to cool down a space or help spread heat. That may be what your issue is-- it's probably set to help spread heat rather than cool things down. I hope this helps!
Apr 19, 2010 | Hunter 27185 Remote Control
Cannot change the direction of my fan...
Your reversing button for that particular model is on the remote control. There is no button on the fan body itself.
Jan 03, 2009 | Hunter (25417) Ceiling Fan
Dryers Logo
8,102 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
